Thanks no contradiction, to clarify, it has been fine until just the this winter, when the front right has started to go down in extreme cold weather, over night. But the last week or two when the car started raising to the max height if i left the system on, it no longer lowered in the cold and yes I let the system rise until normal height, then i turned it off.
I thought it was the front right height sensor. i have done some more searching and found it could be a wiring ground fault.
if you look at the chart above, (this is straight from the ford manual) according to the symptoms given, if the sensors are correctly installed, then the problem is electrical
double check fuses 28, in the instrument panel fuse panel and fuse 4 and 13 in the engine compartment fuse panel
at the air suspension/steering module, pin 10 (bk/pk) wire is common to all 3 height sensors
pin 28 (pk/w)wire is common to all 3 sensors
pin 7(pk/bk) is for l/f sensor
pin 8 (t) is for the r/f sensor
pin 9 is for the rear sensor
unplug the suspension module and all sensors check each circuit for opens, grounds and shorts
if the circuits are good and the sensors are installed properly then all that is left is the module
