in neeed of some assistance..
crowley12
collingswood
My 93 mark viii is having some issues.. it feels like its misfiring but I replaced the coils, wires, and plugs.. I cleaned the injectors, and the mass airflow sensor... Not quite sure what else it
Could be.. it seems like when I hit the gas the harder I hit it the more it wants to bog out.. its running real rich too.. tps sensor maybe?
Check fuel pressure. Make sure the pressure is good under load.
Fuel pressure gauge, tape it to the windshield and go for a drive. Should stay 32psi +
The compression test was my next step. It's just weird because one day it was fine the next it wasn't.. can it lose compression that quick..
Not likely unless you bent a rod or something but I would just check it so your nit chaseing your tail just in case.
Check the fuel filter, fuel pump pressure and this is a long shot but the gasket and IAC module sometimes a small crack in it will screw things up. Good luck, Gene
