Jay Will
I stripped the threads loose in one of the intake manifold screws, do I need to find a new manifold? It's the 2nd gen v8.
The intake that is attached to the manifold. ...
You're absolutely right this is the wrong bolt it is the one behind this one, the one you mentioned.Okay, so that specific bolt holds the throttle body onto the throttle body adapter. The Adapter is all metal, so I don't understand the prior comment about plastic. Are you sure you are pointing to the correct one? Most people don't remove the throttle body from the adapter, instead they remove the adapter (with the throttle body still on it) from the intake manifold. There is a bolt kind of behind the one you are pointing to that holds the adapter to the plastic intake manifold. Are you sure it isn't that one instead?
Yes sirSo it's the threaded insert in the face of the plastic manifold that the metal elbow bolts to????????
Good deal, I really appreciate all the help. I love this forum, you guys are greatYou are not holding the intake, you are holding the throttle adapter to the intake manifold. Pressure is on your side here, since the manifold is often at negative pressure.
I would think that it would be just a little JBweld, and clean off all of it that squeezes out. Give it a full day to set, and then don't over-tighten that bolt. Let the other three take most of the load.
Anyway, that is what I would try first if I were in this position.
