Is it safe and okay to use the stock JBL speakers with an aftermarket cd player of 180-200 watts? Or do I need to get aftermarket speakers as well, and what about the stock amp, can I use it or will it blow my speakers etc?
Nope.94mark8 said:can you install a new amp with stock wiring?
rmac694203 said:Well if you want the stock speakers to work correctly you have to use the stock amp. The amp has all the crossovers internally. They say that hooking an aftermarket stereo to your stock amp will eventually burn the amp up, but it can be done. I just used a 4 channel amp to run all new speakers. Sounds good too.
