Such as nearly all.
in other words, you can't name any.
I do consider religion to be only a coincidental factor in the middle east. Any religion in the area would likely have been twisted in the same manner. Take world history for an example. Now insert any region with the same problems as you see in the middle east. What happens?
What may explain certain problems in one culture doesn't explain problems in another culture. You have to analyze things on the specifics of the culture, or you take it out of context. Religion in this area of the world is the defining factor and to down play it is to distort the history of a region; to take it out of context to fit into one's worldview.
The multicultural lens through which you are looking at things (though you are probably unaware of it) is a naive ideological viewpoint that reaches conclusion before any examination of the facts (a priori) and any examination of the facts and history is simply aimed at rationalizing that view. That is why your view of the history of this area is so distorted and next to impossible to defend. It essentially takes the Marxist exploitation narrative used to justify egalitarianism and applies it other cultures and internationally. Hence, income gaps, class struggle, etc are what define the problems in other cultures. Never mind the fact, that the history of many cultures, objectively observed shows those factors to be minor at best.
The best you can do is appeal to what seems to you to be "self-evident" truths. But considering that many don't share that ideological lens you are looking through, those "truths" are only self-evident, come across as baseless assertions to you and don't convince anyone.
