DLF
I'm doing some work on someone else's '98 and I thought I'd post a few pics of what I've had to do so far to remove the Sub-Frame bolts in order to replace the forward Sub-Frame support brackets. This will give anyone who's looking at doing this job an idea of what you're getting into on a northern car.
If the bolts aren't rusted into the bushings, and subsequently snap right off, then it's likely that the captured nut will spin. If that happens, no choice but to cut an access hole.
So far I've had one forward bolt snap off, and I'll probably have to cut the bushing off as that bolt is rusted to the bushing sleeve.
The other forward bolt spun the nut, and after cutting the hole and pounding down the ears that retain the nut, I was able to remove it, after a liberal application of PB Blaster. Sometimes it's necessary to weld the ear to the nut, but that should be a last resort as it'll make it difficult to align the Sub-Frame in the future.
Spraying some grease on the end of the bolt after it's reinstalled will help if it needs to be removed in the future. I had thought that I was done with this side, until I started working on the other side.
Because I'm going to have to remove one of the forward bushings completely, I now have to remove the entire Sub-Frame, which means removing both rear bolts as well.
One rear bolt came right out, the other is also spinning the nut, so I'll have to cut another access hole in the trunk floor. I'll post some more pics tomorrow that show the location of that access hole (after I've cut it).
Fun, fun, fun......
Fun, fun, fun......
