386Motoring
I tried searching it. Just checking. Thanks
,Phil
,Phil
I don't like being wrong so I did a little research and it sounds like all overhead cam engines are interference motors and push rod engines are non interference. Is that correct?
the rule of thumb is not weither it's a timing belt or chain but usually naturally aspriated high compression engines are - since they have to have a very tight combustion chamber (the piston comes way up the cylinder) so there is no clearance for valves to be open at that same time.
Yeah, but that's a broken valve, not a broken timing belt or chain. When you're talking interference or non-interference, the valves are presumed intact; it's the stopping of the cam(s) that leaves them in a position to be hit (or not) by the pistons.It's not uncommon for a broken valve to intrude into a combustion chamber in such a way as to have contact with a piston, so EVERY engine can be looked-on as potentially 'interfering'.
I asked cause i found a Lincoln LS that i was told had a bad timing chain and i was just curious what kind of damage i was looking forward to. The Trans was good and i was going to part the rest.
I kinda got confused on all the back and forth...
you said the 3.9L is an interference motor?
Also... does anyone know what to look for to be certain ( besides opening up the upper end)
Thanks for all the responses![]()
Are you in CA? If you just need a Transmission, I have one sitting in my garage collecting dust. It needs new shift solenoids. They come in a pack and are easy to replace. From the dealer, they're $375. I hadn't planned on selling it.
Who 'presumes intact'? Is there a formal definition? I've never seen one!
Please read what I wrote. The piston is a flat top and no 3.9 piston I ever saw even has valve reliefs. The combustion chamber is a classic four valve pent roof. The valve would have to protrude beyond the chamber in order to hit a piston, and factory lift figures make that unlikely.
In order for contact to happen, the most likely scenario would include broken valve-train pieces and not just a timing miss-event.
It IS fairly common to pull the valve-stem/keeper interface through the factory retainer, and 'drop a valve'. This inevitably causes a crash.
KS
nope - Ken was making the comment that it is more likely a broken valve fell into the cylinder and caused damage than that the valve hit the piston head from the cam being out of time (because of a broken timing chain).
