Is this suppose to light up?
Lincoln06V8
Minnesota
Is the headlight switch suppose to light up. I'm thinking its suppose to. Looks like the bulb might be burnt out. And now I lost the bulb for the dimmer switch.
The positions light up, the dial itself does not
Now I need a bulb beacause they dont light up. I also now need a bulb for the instrument dimming switch. Do you know where to get them.
If you need just the bulb, the auto stores do have them, usually behind the counter somewhere. If you need the plastic socket too, then you'll probably have to order that.
I need just the bulb for the headlight switch. But I lost the whole socket for the dimmer switch.
Will they have a bulb for the traction control switch.
I would have assumed that one was LED and not replaceable. If it is replaceable, then they should.
They are all just incandescent bulbs the only led one that I know of is the green parking brake light.
I found video of gen I window switches being disassembled. It has soldered in thru-hole LEDs. I'm sure it's the same for gen II. I also know that the parking brake switch is all LED.
