AmsterDutch
I couldn't agree more with the last two post...upon initial start up the car will idle 1500 rpms and then drop to around 750...my suggestion is get your Cats tested withSo here's an update:
I reinstalled the old upstream sensors that were originally on my cats and all the codes went away. I kept the cheap sensors I got from amazon on the downstream connections. I reset the codes and they didn't come back for 100s of miles. BUT the engine started idling very low (750 RPM) which I knew was not good. When I first bought it the car idled at 1500 RPM.
You guys were totally right about using cheap oxygen sensors. It's causing more problems for my car now. When I start it up it has no power and doesn't want to drive. RPMs are super low and it wants to bog out. I have to put it into 1st or 2nd gear to get it driving properly. I am getting a P0301 Cylinder 1 misfire detected and P0316 Engine misfire detected on startup (first 1000 revolutions) in addition to the P0430 Catalyst system efficiency below threshold.
Can you guys recommend the right/quality oxygen sensors for this car? Downstream and Upstream. I should've done it right the first time.
Infrared Laser Thermometer Temperature Gun also you should always change out all COPs and plugs at the same time...just like plastic coolant parts...O2 sensors won't help much at this point...if they fix your problems I will be truly amazed
