Ok, Mr. '03 Mustang; You push more air out of your exhaust than a stock Mark VIII and will be louder. You are supercharged and according to Wikipedia; "A supercharger (also known as a blower) is an air compressor used to force more air (and hence more oxygen) into the combustion chamber(s) of an internal combustion engine than can be achieved with ambient conditions atmospheric pressure.
The additional mass of oxygen-containing air that is forced into the engine improves on its volumetric efficiency which allows it to burn more fuel in a given cycle - which in turn makes it produce more power.." With all due respect, your owner ought to know this, as he is an ace mechanic.
You have taken out the cats that would tone down the note and an X-pipe increase the exhaust note even higher. (Double hit for higher pitch). Mark VIIIs have a few feet more tubing in the exhaust system, thus a slightly lower pitch.
From Wikipedia;
Loudness is the quality of a sound that is the primary psychological correlate of physical intensity. Loudness, a subjective measure, is often confused with objective measures of sound intensity such as decibels. Filters such as A-weighting attempt to adjust intensity measurements to correspond to loudness as perceived by the average human. However, true perceived loudness varies from person to person and cannot be measured this way.
Tone may refer to:
In music:
* Pitch (music), the perceived frequency of a note or sound (see also pure tone)
My SBC 350, 5.7l through open exhaust is louder than my Linc. 281, 4.6l. You can ask my neighbors. Outside measureing the dbs. for a scientific approach. Arguing over this gut feeling is fruitless. See above definitions.
Hondas and like ricers have that higher pitch that makes them annoying from less air presssure(4cyl.) being pushed through a large "coffee can muffler", sounding off that nasty, raspy, resonance ridden tone. As oppossed to an 8cyl. through a smaller pipe, resulting in a deeper tone.
All in all, WOT is for a brief moment in time. IMHO, early a.m. initial engine start up for neighbor sake and cruise RPM maybe the better considerations for overall exhaust tone set-ups. As stated above, sound is subjective to the end user and ultimately decided by that user.
