JamesVinar
Well I just got a mark viii and it has some issues, some I knew about when I bought it like the windshield and air ride but those are easy to figure out. There's maybe two separate ones that I really need help with 1 is getting the car started, sometimes it will start and other times the check engine light will turn on and the anti theft will flash or stay on when the key is turned to the right a little then when I turn as if I was cranking it everything dies out. I'm not sure if it's the battery or pats since it will start sometimes with the key. Im thinking it's my battery because when I put another one in it started just fine but when I came to restart it it wouldn't go. I put it on the charger overnight and will try again later but if it works then it's a charging problem. Is there anywhere besides the alternator to check?
The second is the lock and unlock buttons on the door are not working
Last is the gear ratio. I heard some 98 lsc came wits 3.73 lock diff is this true?
