AmsterDutch
Yes it should work on your 2002 ...I'm having issues with my 2002 LSE ...having a Can error and Bus errorI have a 2002, so why do you say that?
Why wouldn't I say that? You were worried about it working and I am telling you that it will work for a 2002. I use one for a 2001 so why wouldn't it work?I have a 2002, so why do you say that?
Look again that was not me. @AmsterDutch was just saying he had problems on his 2002 LSE. I have used the ELM327 Modified with the switch on a 2000,2001,2002 and 2006 Lincoln LS and it works just fine. I have flashed modules on all them cars as well with no problem using ForScan with the ELM327 modified.Because you said you had issues with it on your 2002 lse.
UPDATE: SteveSC I just found out why the adapter wasn't working ...of course the last place I would look is... on the adapter itself....lol...in my haste and NOT THINKING! I looked down at the adapter today and low and behold the two Pins in the middle of the adapter were bent over towards the plastic wall inside the adapter where the Pins sit...UGH! Yes I'm not the sharpest tool in the shed at times...anyway rest assured that the ELM327 Adapter will work for you and now it's working in my 2002 LSE 3.9Because you said you had issues with it on your 2002 lse.
Yes that is the one I have ...you can rest assured ...this product will work for youhttps://www.amazon.com/gp/product/B01N18TOFB/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I ordered this. Is it the right one or will it work?
I agree I wish they didnt design the climate control this way ...but I have gotten use to just turning it off ...now it's almost automatic that when I turn the defrost or heater on I just hit the AC button per ritualbut if I just want a little airflow I don't want it to turn the AC on!
You can have a locksmith cut the keys
