I believe I have read that Ford, in a rare moment of lucidity, re-designed the 4.0 Jag engine, to sport iron sleeves in the cylinder bores, instead of the "coated" aluminum...Wouldnt this be a better plan, for a performance engine?
For those who might be interested---
I arranged, this morning, through a 'verbal handshake', to write a short item for a Primedia publication regarding our record runs at Maxton. I'll be sending in the story and photos within the next week or so and it usually takes at least six weeks before it would appear in publication. Depending on where the editor is in his work, it may well take longer than that. The photos will be other than those I've shown here and the copy will give a narrative of the past season. Future stuff will focus on the new engine and trans build and next season's activities
KenS
I had an extensive discussion with my rod manufacturer this afternoon. He's suggested that it may be necessary to turn the rod throws on the crank to 1.89 Honda size in order to have room in the crank case for the rod big ends. I'll be sending him a rod to work from. More soon!
KS
It's my goal to get an engine and trans setting, ready to go, and then in a matter of just two-three days, put it in and have it running. If I were to pull the original engine out, it would surely take several weeks to machine and assemble---and then dyno---the original package. It IS my daily driver.
KenS from Ben's Place
I've noticed in other places on the forum a continuing concern regarding the exposure of the intake/filter under the car. My own approach is simple---extend the air intake up into the trunk, and create a plenum in the space directly behind the wheel house. That area will be covered with a Dzus-fastened panel, for ease of access and the air intake will be accomodated by a NACA duct through the quarter panel. I'll post photos as this develops over the winter.
I have no doubt that you're correct. And I probably wouldn't do it myself except that I really do drive the car year 'round and the weather here in the Metro Detroit area is surely about the same as it is where you are. In addition, to tell the truth, although I only run the sponsor panels on the doors during the race trips, I get a kick out of the classic double-takes I can see from the corner of my eye when stopped at a light. Little 'hints' such as hood pins and NACA ducts should only increase the reactions. And the studied subsequent 'looking-the-other-way' from the ricer kids with their six inch exhaust outlet only makes it better.
On another note, my friend Ben suggested that I tell you that I only turn on the spray after going into third gear at Maxton. And since I'm already doing over 100 MPH by that time, I purposely don't purge the 'spray' line so as to get a softer 'hit'. That technique, along with the unbelievable bite of the 245/45 ZR18 Michelin P-2s, means that I have no traction problems with an over 100 HP spray package. We'll see what happens next season---I'm going to use a 200 HP shot and start it at 3K in first.
KenS from Ben's Place.
Aluminum rods in a daily driver?
Can of worms opened...
