cammerfe
Methanol as a primary/secondary fuel
As a primary fuel for an internal combustion engine, methanol has both drawbacks and benefits.
Benefits-
1. Contains oxygen as part of the molecule; therefore helps support its own combustion.
2. Heat of vaporization is such that the combustion process is quite efficient.
3. Readily created by distillation of cellulose/plants.
Drawbacks-
1. Quite corrosive
2. Hygroscopic; easily contaminated by moisture from the atmosphere
3. Has less caloric content than equal amount of gasoline; therefore requires more volume as fuel to do equivalent work.
4. Poisonous; dangerous to drink or even to inhale.
Due to benefits #1&2, a spraying of methanol into the incoming airstream of an internal combustion engine will both cool and enrich. Properly done, such a spray will obviate the necessity of an intercooling structure in the intake tract.
There's lots of room for discussion here!
KenS from Ben's Place
Benefits-
Drawbacks-
1. Quite corrosive
