G-RELL
FULLY DIPPED LS
the only way you could match results of a "dry" mount compared to the LS's, is to use a softer rubber/ compound. Which you would destroy twice as fast. stick with the OEM on this one
fluid filled mounts...wow. I'm going to assume no one makes a solid or something not filled with fluid
I'm sure you could cobble together some sort of polyurethane mount. It would definitely not have any foreseeable problems with a stock LS. It will however make the car feel like you bolted your seat directly on top of the engine.
lol, you say that like it's a bad thing!![]()
Well, the good part is at least you're versed in removing the AC compressor now, so hopefully it will be easier for you on the 06.
Ugh, if I ever need to remove the compressor I know who to talk to! Are you going to do the motor mount yourself? Going to rent the special tools?
