RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,734
- Reaction score
- 523
RE: Let's talk V6's!
Let's say we did BUT didn't.
LOL.....have a nice tall glass of Haterade
Any other secrets when removing the intake? Looks like you have to split it and try not to disconnect the coolant hose.
LOL, mine is Italian/German/Canadian with a Fn attitude!
~ hard to find good sandwich makers these days BUT she does take out the trash <only cuz I'm not home on those days>
You have to unbolt a support bracket on the front of it, below the throttle body, and loosen by a couple of turns, a bolt on a side support bracket midway down the right side of the engine. You also have to remove the protective bracket at the back end of the intake by removing the rear two bolts from the upper intake and the egr pressure differential transducer, because that bracket forms a surrounding protective barrier for the back end of the fuel injection rail. If that doesn't come off, the manifold will never move up or over to give you room for the plugs and coils on the right side of the engine. You also will need to remove the EGR pipe from the EGR valve, so make sure that you have a wrench that will go as wide as 1-1/4" or so for that nut. Also disconnect the vacuum lines and wires for the EGR solenoid valve. Oh, and remove anything else that looks like it obviously has to be disconnected.There should only be 8 bolts that you have to remove that go down through the intake upper assembly into the engine. If you find more bolts, leave them in place, as some hold the fuel rails to the lower intake, and some hold the lower intake into the engine. They can all stay put.
FWIW, my BEST time changing the plugs on my (now my daughter's) old V6 was 3 hours; first time was in the 5-6 hour range. Many pieces must be moved/removed to access the passenger side plugs/coils.
See if you can find an indie that can do the job. It isn't that difficult, just time consuming.
The DCCV is also a bear. The V6 is more labour intensive than the V8; even though there is generally more room.
NGKs platinum tips are good, or you can use Motorcraft platinum tips. I would stay away from any of the gimmick plugs with the multiple ground leads, rings, ect. Don't use the spark plug gap measuring tool to adjust as this will damage the platinum tip. They make a gapping tool for this job.
What do you use on platinum plugs to set the gap.
Something like this is good enough: http://www.amazon.com/Tools-2327-Sp...=1438867681&sr=1-1&keywords=plug+gapping+tool
Don't use the gauge to force the gap bigger, use the other part of it to bend the ground electrode: https://www.youtube.com/watch?v=lk70oyUEftY
