cammerfe
Cometic Gasket Co. seem to think that they can supply gaskets to mate LS heads to a Jag block. I guess it remains to be seen!
KS
KS
I believe recently someone posted that the camshaft stampings from the Jag and the LS engine are the exact same part number.
Someone correct me if I am wrong....
KS
Those blocks look so similar as far as im concerned we have a 4 liter engine.
Hi
Just want to say that we have successfully made a swap of engine from Jaguar S-type 4.0. We take block and heads but have to change 2 of camshafts (1 on each head is from LS and 1 is from JAG). Intake, outtake from LS fit very well. All sensors came from LS. As dwiggy said - we had to also reuse mounting bosses from LS block for hydraulic clutch pump. Sump was also reused from LS because of mounting bosses for alternator.
In my opinion now engine have few horses more, maybe due to bigger capacity of the block. Also engine, due to bigger weather channels warms it self faster, which is good because i can play with gas pedal faster
Currently I'm thinning about taking a compressor from Jag XJR, and brakes and hub's from Jag S-type R
Also, did some research on the forum on other problems - we have winter, and my seats don't heat. Changed all three fusees, but that didn't help. Also rain sensor don't work. Maybe somebody know what can be the reason of that? And sometimes airbag light comes up.
Great to hear, Jajo!
When I was a kid in the '70's, the thought of ever meeting, or speaking to, a Pole was crazy. The only thing I knew about Poland was a guy named Prime Minister Jaruszelski. Now we have a Pole blazing a trail on the LS! Love it.
The heated seat problem is probably due to a break in the wires of the heating element under the seat cover. You can replace the heating element or solder the break. There is a thread going right now from marcredd on that topic.
For the airbag light, count the flashes. They should be a two digit code. Most likely you'll get 3 then 2 or 3 then 6. Check the connector under the seat for a break or loose connection (in your case a loose connection since it's intermittent). If things start going wrong in your steering column, like the cruise control or other controls or possibly your intermittent wipers, then you probably have a worn / broken clock spring. That's also been covered here many times.
The rain sensor has several topics here, as well.
hi I'm new to the site, Hope you can help me I have a 2001 jaguar stype, and want to put cams and solid lifters out of Lincoln ls 3.9 on my jaguar 4.0..will it work? thank youCometic Gasket Co. seem to think that they can supply gaskets to mate LS heads to a Jag block. I guess it remains to be seen!
KS
There are no 'lifters' in your engine. The cams work directly against 'buckets' that fit between the overhead cams and the upper end of the valves. These buckets contain shims that set the lash for the individual valves. In other words, direct action---no rockers, lifters, or pushrods.
KS
I have two good ls heads...and one of my jag intake cam is damaged..if I change cams the solid lifter must follow the cam in which it has seated too.I don't know about Jag, but Ford calls them tappets, not lifters. I don't know if you can use the 3.9 cams and tappets in a 4.0.
Doesn't the 4.0 already use solid tappets?
Why are you wanting to use the 3.9 parts?
I REPEAT---There are no 'lifters' (or tappets) in the engines you are referring to. ...
This is a new terminology/word very interesting I always have called them lifters but just goes to show the richness of this forum and the expansive knowledge given on it...that's the reason I always recommend Seafoam injector spray cleaner which allows a good HOT SOAK for the engine it helps the Tappets/Lifters and brings them back proper performanceWhile I do agree that they aren't "lifters" in the traditional sense, Ford does in fact call then "tappets." I do think it is the correct term. (It also seems that "lifter" is not an incorrect term for them either. New to me too, live and learn.) You may be defining "lifter" too strictly. I don't know why you are opposed to the term tappet.
The page in the shop manual on the valve tappets: 2006 Lincoln LS Workshop Manual
Exploded valve train view:
NOTE: RH shown, LH similar.
Item Part Number Description
1 W701242 Intake camshaft cap bolt (10 required)
2 6A258 Intake camshaft cap (5 required)
3 6A270 Intake camshaft
4 W701242 Exhaust camshaft cap bolt (10 required)
5 6A258 Exhaust camshaft cap (5 required)
6 6A272 Exhaust camshaft
7 6K514 Tappet shim (16 required)
8 6500 Tappet (16 required)
9 6518 Intake valve spring retainer key (16 required)
10 2762 Intake valve spring retainer (8 required)
11 6513 Intake valve spring (8 required)
12 6A536 Intake valve stem seal (8 required)
13 6518 Exhaust valve spring retainer key (16 required)
14 2762 Exhaust valve spring retainer (8 required)
15 6513 Exhaust valve spring (8 required)
16 6A536 Exhaust valve stem seal (8 required)
Definition of tappet: Tappet - Wikipedia
A tappet is a projection that imparts a linear motion to some other component within a mechanism.
...You'll notice that in the Wiki article, there is stated that the 'tappet' contacts the cam. Going by that definition, you may be able to call the shim a tappet, but not the bucket itself. ...
ok Tappet..old school is Solid lifters..Lol
Got Two low mile heads off of Ls3.9 and I got take head off of jag due to wife running hot probably dropped a valve seat or valve stuck open. I know the head bolts will work. just wondering. might sell the ls heads..What ever you or I want to call them, I suspect (but don't know) that they will work. The bigger question to me is the cams.
Are you really saving that much going this way?
