Quik LS
most LED are 5v - so you'll have to select a resistor that creates the proper voltage drop given the number of LEDs and amps they will draw.
in my LED turn signal mirror project - I used nine LEDs soldered in parallel and then used s 560ohm resistor on one leg to drop the voltage to the proper 5v.
most of the newer bright LEDs are very directional in light - so people usually use many LEDs or create rings in reflectors to get more light 'filling' the area.
