NYC LS8
DING!
Nice!
The only issue would be re-installing it then, since the new case is different all the shims need to be changed as well right?
Nice!
So there won't be any change in the backlash on the ring gear as long as the same shims are used?
Nope. The case is the EXACT same size where the shims have to go in both diameter and width. I measured them both to the nearest 1/1000th inch on my mill. You can reuse those from your 8.0" differential if they look to be in good condition.
I also have a 8.8" POSI unit for sale for $100 if anyone is interested. not the entire diff, just the posi unit to go inside of the stock casing.
Well I decided to finally get off my tail and do some measuring today to see what ways a LSD could be installed into the stock Lincoln LS differential carrier. There were two other viable options that Jason and I had thrown around.
1) Do a powertrax unit into the stock 8.0" diff case.
2) See if an 8.8" 28 spline differential would bolt into the LS 8.0" carrier while using the stock LS gears.
I know I had mentioned I planned to get to this and I finally did today. Tore the 8.8" down first. Took my measurements. Then it was time for the 8.0" LS diff teardown. Did that and took a few more detailed measurements. So far everything was a perfect match. Then I decided I had better unbolt the 8.0" ring gear and see how it measured up to the 8.8" ring gear bolt pattern. Same, 10 bolt pattern same OC measurement. I finished bolting the 8.0" LS ring gear onto the 8.8" differential and then bolted it all back into the LS carrier. Long story short... It was a dead match in every way.
I decided not to even measure for the Powertrax option as it will be the more expensive option of these two; though slightly more easy to install.
Now as some of you may know, we had already did the 8.8" full differential assembly swap in Jason's LS with a 8.8" LSD w/ 4.10 gears and a custom diff brace built by me. I wanted to discover if there was something a little more bolt in for those of you that just wanted an LSD but still stay with the 3.31 or 3.58 LS rear gears. This is it. So far I have only tested this on the Gen1 LS differential but have no reason to believe that it will not work with a Gen2 LS differential also. Once I do the differential swap in the springtime I will let you all know the official Gen2 results.
This will be a good mod for those of you planning to either to my turbo system, a roots supercharger like Quik or a nitrous system. No more one wheel wonders.![]()
EH... I'm sure if someone really wanted, they could have 4.10's made for the 8"... or you could possibly have 8.8 gears modified... not sure which would be more expensive.
Im working on that now
I have a manufacturer looking into the differences.
That's funny, I'd contacted them this summer about putting in an LSD and they said they had a unit there tore apart and hadn't been able to get the old school 8" to fit. Must have been you they were working with!
