lincolnfam
I heard rumors that a Quaife QDF3W lsd for the jag S type R works since I believe 03+ STR shares the housing with gen 2 LS? I stopped doing research. a bit pricey but less work if it fit.
Gary the parts cost will only consist of a Limited slip differential of your choice and that is it. You reuse your stock CV shafts (axles), stock carrier, and stock ring & pinion gears as well as the shims (if they are in good condition). For a somewhat skilled home mechanic the swap will probably take no longer than 2 hours while screwing around.
The LS diff is 28 spline and the Mark VIII diff's are 28 spline. The 99-01 Cobra's use a 28 spline 8.8" diff too. Stock gearset will be reused unless you are want to swap up to the Gen 2 LS 3.58's. Stock driveshaft reused.
Yea I get that. I have done 60 or 70 rear ends in my 32 years as a techI went back and started re-reading this thread. You got your answers in the first 4 posts.
So the short answer is that any 28 spline 8.8 limited slip will work in the Gen 1 LS. You just re-use the original ring gear that was in the open diff.
The set up, installation, and adjustment can be a bit tricky... so if you have never done this type of work before, you may want to have a professional do it. Otherwise you could grenade the rear end. If that would happen at high speed... the results could be fatal.
So it has to come from a mark 8 or 97-01 cobra? Any 8.8 won’t do? Previously in the post it says 8.8 of your choose but then mentions mark 8 or 97-01 cobra
Cool cool. Thank you!Don't forget that the diff tag will have an "L" in the ratio number... such as 3L55 or 3.55L . You will still want to use the ring gear from your original diff. That should be either 3.31 or 3.58 .
Todd and smegun,
You have the luck of owning a Gen 1 LS. The housing is slightly different from the Gen 2... and the Gen 1 will accept an 8.8 posi unit allowing it to pretty much drop right in the housing... allowing you to use the factory gear set.
I don't remember the details... other than the 8.8 posi had to be the 28 spline version, (like from a Mustang)... to match the axles of the LS.
You might want to dig around in the "LS performance" section of this forum... and maybe contact member "Quik LS" or "Cammer FE", (if they are still around), for more details.
thought we were talking about an lsd a posi rear now were really talking does it have enough torque for these ? he ha
how is the experiment goingSame thing. Different name.
With a clutch posi you might hear some grinding/popping while making slow turns, like in a parking lot.
Due to the limited space in the LS rear end... I doubt the Truetrac would even fit.
Keep in mind that the Gen 1 LS diff is only 8.0. So the 8.8 diff will barely fit... and only with smaller gear sets.
You might get 3.23, 3.31 or 3.55 gears in there... but don't plan on getting 3.73 or 4.10 gears in the 8.0 diff. The ring gear will be too thick.
I dont want chirping and any unnecessary noises in the rear , so decided on the truetrac.
that is a eaton nospin/detroit locker not a eaton detroit trutracOn acceleration... the Truetrac acts like a locker diff. The car will want to go straight in turns.
How well do you think that's going to work out for you?
