Imanol Alamillo
Hi guys, it's been a while since I posted a while ago about COP's going bad on my LS. Since then the car ran fine (changed the COP's at about 27,000km and now the odometer reads close to 55,000km).
The problem is the engine lost compression all of a sudden. The car was running fine as always when I parked it in the afternoon, and next day tried to crank it and it sounded like if it was freewheeling (like it sounds when a timing chain breakes and there is no compression on the engine).
Already checked compression and is very very low (50 psi average on the 8 cylinders
I also removed both valve covers to check timing and all the chains/tensioners/guides are ok, no loose chains and the timing marks on the camshafts line up as they should.
I read about the nikasil blocks suddenly failing and wanted to know if there is a chance mine could have this problem. The build date in the engine is 27/01/2000.
Thanks in advance!
Thanks in advance!
