Thanks for the info and the link. Looks like I may have another mod for the LS next month.What is the tire size you used? and what brand? And by the way that is one sexy looking car.
I agree with you 100% on these statements. Those Sentas are heavy!It is my opinion the Senta's with 245x30x20 would most likely not rub at all without adjustment and do have a 1/2" smaller diameter than the stock 17" wheel/tire combo...you would just give up some ride comfort/cornering. Be aware that the 20" Senta's are a heavy wheel at around 58lbs (with tire) vs. 47lbs stock 17". So you will give up a little power and braking effectiveness. I think I read somewhere every pound of rotating weight equals 7lbs of non turning weight on the car.
I actually installed them on Sunday. While idling, the fronts would rub the wheel liner when turning the steering wheel to full lock. However, I have not experienced any rubbing while driving. Go for the 255s!hey ohtree ls, have you bolted up all four corners yet with the 255s?
they will rip your front driver fender off if you are taking a turn and hit a dip, like entering driveways and normal turns from street to street.. if you drive careful you will be fine if not move down to the 30 instead of the 35 , maybe u will have more luck then
Here are some pics
