Ok, I didnt bother to search to see if someone has previously posted this information, but I meantioned a ball joint recall for the 2000 model LS and I figured I post the other recalls I have found as well. AS FOR THE RECALL I mentioned in a different thread I said it was good for LS's between 00-02. I WAS WRONG. If your lincoln was manufactured between 8/98-09/00 then it falls under the ball joint recall. Check the manufature date.
#Safety Recalls
NHTSA Safety Recalls:
Important: The following recalls were issued for the 2005 LINCOLN LS by the National Highway Traffic and Safety Administration (NHTSA). To find out if a specific 2005 LINCOLN LS still has open recalls that require repair, CARFAX recommends contacting an authorized dealership for more information.
Recall date: 04-04-2005
Units potentially affected: 56
NHTSA campaign number: 05V113000
Defective part or component: FUEL SYSTEM, GASOLINE:STORAGE
Description: On certain passenger vehicles, the fuel tank may have a localized thin wall section in the lower half of the tank. The fuel tank may crack, creating a potential for a fuel leak and fuel odor. The ""service engine soon"" indicator may illuminate. Fuel leakage in the presence of an ignition source could result in a fire. Dealers will replace the fuel tank free of charge. The recall began on April 4, 2005. Owners may contact Ford at 1-800-392-3673, Lincoln at 1-800-521-4140.
This 2005 LINCOLN LS safety recall information was provided by the Insurance Institute for Highway Safety, Highway Data Loss Institute and is derived from the National Highway Traffic and Safety Administration list of safety recalls. Please call the National Highway Traffic and Safety Administration Auto Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236) to report safety defects or to obtain information on cars, trucks, child seats, and highway or traffic safety. CARFAX does not review, validate or edit the information and statements provided by the National Highway Traffic and Saftey Administration, which do not represent the opinion of CARFAX.
RECALL: 2004 Lincoln LS
NHTSA Campaign Number: 05V113000 www.nhtsa.dot.gov
Manufacturer FORD MOTOR CO.
Recall Date: 03/18/2005
Potential Number Of Units Affected: 56
Description FUEL SYSTEM, GASOLINE:STORAGE
Summary ON CERTAIN PASSENGER VEHICLES, THE FUEL TANK MAY HAVE A LOCALIZED THIN WALL SECTION IN THE LOWER HALF OF THE TANK. THE FUEL TANK MAY CRACK CREATING A POTENTIAL FOR A FUEL LEAK AND FUEL ODOR. THE "SERVICE ENGINE SOON" INDICATOR MAY ILLUMINATE.
Consequence A FUEL LEAK IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE.
Remedy DEALERS WILL REPLACE THE FUEL TANK. THE RECALL BEGAN ON APRIL 4, 2005. OWNERS SHOULD CONTACT FORD AT 1-800-392-3673, LINCOLN AT 1-800-521-4140.
RECALL: 2003 Lincoln LS
NHTSA Campaign Number: 03V136000 www.nhtsa.dot.gov
Recall Date: 04/07/2003
Potential Number Of Units Affected: 1736
Description WHEELS
Summary ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH 17 INCH CHROME WHEELS, THE CHROME WHEELS WERE NOT HEAT-TREATED. THESE WHEELS MAY CRACK AT THE LUG-NUT HOLES, WHICH COULD RESULT IN THE LOSS OF THE LUG-NUT TORQUE.
Consequence IF THIS CONDITION OCCURS, THE DRIVER MAY EXPERIENCE NOISE AND/OR VIBRATION WHILE DRIVING THE VEHICLE. CONTINUED OPERATION OF THE VEHICLE COULD RESULT IN THE WHEEL SEPARATING FROM THE HUB, INCREASING THE RISK OF A CRASH.
Remedy DEALERS WILL INSPECT THE WHEELS TO MAKE SURE THAT ALL THE WHEELS HAVE BEEN HEAT-TREATED. ANY WHEEL THAT HAS NOT BEEN HEAT-TREATED WILL BE REPLACED. OWNER NOTIFICATION BEGAN APRIL 14, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT LINCOLN AT 1-800-521-4140.
NHTSA Campaign Number: 00V359001 Vehicle/Equipment Make: LINCOLN Vehicle/Eqipment Model: LS Model Year: 2000 Mfg Campaign Number: 00S39 Mfg Component Desc: SUSPENSION : FRONT : CONTROL ARM : LOWER BALL JOINT Mfg Involved in Recall: FORD MOTOR COMPANY Manufacture Dates: 08-18-98 through 09-29-00 Type of Report: (V) Vehicle Potential # of Units Affected: 82,300 Date Owner Notified by Mfg: 11-24-00 Recall Initiated By: MFR Mfg Responsible for Recall: FORD MOTOR COMPANY Report Recieved Date: 11-03-00 Record Creation Date: 11-03-00 Regulation Part Number: FMVSS Number: Defect Summary: VEHICLE DESCRIPTION: PASSENGER VEHICLES. THE FRONT SUSPENSION LOWER BALL JOINTS WERE NOT TIGHTENED TO SPECIFICATIONS WHEN THEY WERE ATTACHED TO THE LOWER CONTROL ARMS. Consequence Summary: IF THE BALL JOINT ATTACHING NUTS ARE NOT ADEQUATELY TIGHTENED, THEY CAN LOOSEN AND, ULTIMATELY, RESULT IN FRACTURE OF THE BALL JOINT STUD. IF THE BALL JOINT FRACTURES, CONTROL OF THE VEHICLE COULD BE AFFECTED, INCREASING THE RISK OF A CRASH. Corrective Summary: DEALERS WILL INSPECT THE TORQUE ON THE TWO BALL JOINT ATTACHING NUTS. VEHICLES WITH LOOSE BALL JOINT ATTACHING NUTS WILL EITHER HAVE THE FASTENERS TIGHTENED TO SPECIFICATION, OR IF NECESSARY, THE BALL JOINTS WILL BE REPLACED.
#Safety Recalls
Description WHEELS
