Looking to get an ipod module
I would like one that charges it, but if it not that's ok too. I'm just clueless as to which one will actually work with my car. It has the in dash cd changer too if that helps anyone.
Here's the one I got. . .
http://www.icarkits.com/advanced_search_result.php?select_vehicle_make=16&select_vehicle_model=104&select_vehicle_year=2000&vehicle=16%7C104%7C2000&set_vehicle=1&sort=4d
It works great. iPhone compatible as well. It, charges the phone/ipod and lets you use the steering wheel controls to switch songs. The one I linked to above is for the 2000 LS with the in-dash CD changer. It came with the proper wiring harness making it a very easy install.
The top one you linked to will not work. You need some kind of pass-through cable. The second unit looks very similar to what I have.
k guess I'm going to have to do some research on all of these, already found that some of them don't work with the in dash cd changer so those are out. thanks for all the help though!
If that doesn't work check this out -
http://www.discountcarstereo.com/detail.aspx?ID=813
It's not the full ipod system, it doesn't let you control it via the car/radio controls, but it does let you do line-in to the radio. What I did was use this + a Sik Imp (no longer making this specific model) to charge the ipod & use line-out/the botton connector of the ipod for best sound quality.
