warrioralumni08
Hey guys, I need help. Long story short, lost keys at work to the car, only had one key, car is currently locked too. What is my best option? Locksmith or Ford dealership?
Appreciate it. I believe the car has a feature where it also disengages the trunk pop button and fuel pump when unlocked correct? ...
... I assume the alarm will go off, thus probably best to get the locksmith to open the trunk first, so i can disconnect the battery? Then lay the seats down and unlock the doors.
... Hopefully programming a new key should be a breeze for him.
Couldn't the dealer or (licensed) locksmith provide a key using the car's VIN?
plus Ford (mine anyways) will not cut keys off vin's for cars older than 6 years...
will not or cant? maybe they were not keeping the key code (for the cut, not the PATS) in there system before that?
I worked for Hertz in 1982 - we had key codes to cut keys then.
so the question is, where you accessing the dealer's database, or were you recording the info once you received each car so you had it in your own database?
