Okay I've searched Now heres what I've got.
KOEO in this order
524 low speed fuel pump circuit open(pump runs fine)
543 fuel pump circuit open-Battery to PCM ( pump runs fine)
Running I get these
136 Can't find it anywhere!
172 O2 indicates lean This is possible but I have some black plug after maybe 30mins of running so I'm thinking not.
This car has 2 broken knock sensors However when you pull the shut it should go to 10 degrees BTDC and not accept timing from the PCM It runs the same with or without shunt at idle. I know the knock sensors are bad but the car should idle and it will for a few minutes. That 524 really gets me. I have had the plugs out and they looked golden but the last time I pulled them some where quite black I installed new ones and wires, it would not idle at all before the new plugs and wires. I change 1 O2 sensor but not the other. It is possible the other one is bad and maybe its saying lean when the plugs say I'm black, and can this relate to the 534 code.
So one question I have is can the 524 code be caused by the o2 sensor asking for more fuel at idle which could cause the pump to go to normal speed. I have found this code in searches and have seen the fix be an o2 sensor. This makes sense to me if the low speed is only used at idle.
I'm not sure when the low speed pump circuit is in play does anyone know.
KOEO in this order
Running I get these
