Only cause no one wants a V6![]()
However my V6 has no problem with leaking V/C gaskets to screw up my coils,
no transmission problems has all the options and better fuel milage.
So go and fix your V/C gaskets and while you are at it replace all the COP.
Good Luck and have a nice day.
By the way also have a look at your DCCV with the hose outlets for the useless coolant pump outlets that go nowhere. Ford installed this extra pump to keep your V8 running at a reasonable level, without this pump you most likely will overheat you well designed V8.
Now go LYAO
