If someone could show a historical correlation between tax rates and the economy, I'd sure like to see it. All I hear is theory.
Are you positioning yourself to say that tax policy has no influence on the economy? That the economy and entrepreneurs function without regard to or influenced by the tax policy? And that it doesn't negatively impact the economy when money is forcefully seized from investors and citizens and dumped into D.C?
But I suspect you've purposefully posed a question that you know will never be answered to your satisfaction. Because of the needless complexity of tax policy in this country, there's no way to present such information without it being subject to interpretation.
Obama has recently started using the rhetoric of how tax rates, even after the Jan 1 tax increase, will still be lower than they were under Eisenhower and early in Reagan's tenure. On it's surface, this would seem like something easy to discuss, but it fails to note that there were far more tax brackets then. It also fails to note the vast array of accounting tricks and deductions that were used to avoid such taxation.
So the rhetorical trap set here is for me to present the period of sustained growth following the Reagan tax cuts, and then for you to use the fact there was a 70% tax rate in 1981 (though Reagan continued to work to cut these rates throughout his Presidency bringing them BELOW current rates today by the end of his Presidency.)
To keep this simple, I'll just point out the historical reality.
Reductions in tax policy have been used to stimulate economic recovery throughout the past century.
It was done in the 20s, leading to the "Roaring 20s."
They dropped rates from 70% to 25% and included deep federal spending cuts. Tax revenues ROSE by 61% following the cuts because of economic activity.
It was done in the late 40s by the Republican congress, finally helping to pull the U.S. out of the depression/recession that had started under FDR and Hoover.
It was done by JFK with his across the board tax cuts in 1961. They lowered the top rate from 90% to 70% yet resulted in another 62% increase in revenues.
And it happened again under George W. Bush.
It was done in the 80s by Reagan. Deep reductions in the tax rates and deductions that lead to increased economic activity and tax revenue generated.... but that's something you appear to want to discuss:
Tax revenues increased by 99.4% by the end of the 80s, that is absolutely true, despite cutting the top rate from 70% and gradually falling to 28% in the LAST YEAR of his Presidency in 1988. You have to include the entire decade inorder to calculate the economic impact of the last tax cut.While I'm at it, there's something I'd like to point out on that last link. The right loves to claim that "tax revenues doubled under Reagan". This is a myth. The only way you can arrive at that conclusion is by counting the entire decade of 1980 to 1990 and use real (non-constant) dollars. Yet, no matter how you count it, the decade of the 80s was behind every other decade in terms of revenues. Even the 70s beat the it in terms of real, constant, and percent of GDP.
If tax cuts didn't stimulate economic activity, how else could such a radical drop in the tax rate (over 40%) result in such a steep increase in revenue generated? Some can be attributed to the fact that when tax policy isn't overly punitive, people have less incentive to find creative ways to avoid paying taxes. And while that isn't sufficient to explain the entire increase in revenue, it does further support the argument for a lower, less complicated tax policy.
But to address you issue of real dollars
Federal receipts equaled $517 Billion in 1980
In 1990, they equaled 1.032 Trillion.
But, in constant dollars (Y2005), 1980 receipts equaled $1.2 Trillion dollars
And in 1990, they equaled $1.51 Trillion. So, despite your claim, and despite reducing the top rate by over 40%, revenue INCREASED by 3 Trillion dollars.
And to correct your claim about taxation as a result of GDP-
The tax revenue collect as a percent of GDP was 19% in 1980.
In 1990 it was 18%.
Also interesting and significant-
The share of income taxes paid by the top 10 percent of earners increased during the Reagan administration despite the reduced rates. It went from 48% in 1981 to over 57% in 1988.
The top 1% of earners paid even more. Their share of the budget raised from 17.6 in 1981 to 27.5 in 1988.
Yes, taxes are the lowest right now since 1992, but we are facing across the board tax INCREASES come January 1. And, as you've noted, these would be significant tax increases during "the worst bust in 80 years." That is economically suicidal to do.Taxes are currently at the lowest levels since 1992, yet we've had several booms and busts since then. And right now we're in the worst bust in 80 years. Yet if all it takes is lower taxes to boost an economy, then we should be seeing the best times since... wait... weren't the 90s our last big boom? Back in the day after Clinton raised taxes and Republicans told us the sky would collapse (I can provide quotes if needed)?
It doesn't JUST take reduced tax rates to restore the economy, but raising them will undermine it.
I can argue that the economic strength of the 90s was a byproduct of the economic conditions that were created by the Reagan economic policy. Things were prosperous enough, and we had a "bubble", so that the tax increases were absorbed. It was also important to note that the economy DID dip in 1992, creating the economic and political situation that enabled Clinton to be elected. "It's the economy stupid."
It's also critically import to remember that the Congress changed parties in 1995 and they, briefly, imposed fiscal discipline on the President.
There are a lot of conditions and factors at play, the tax policy isn't a silver bullet to everything, but it is a significant factor when trying to manage and observe the economy.
Yes. There's something called the Laffer curve that displays this point.So it would seem that lowering taxes gets diminishing returns at some point.
If we were way "over on the curve, that means revenues would have fallen sharply.In other words, looking back at history, it appears that we're currently way over on the left side of the mythical Laffer Curve.
Basically, you're presenting a schizophrenic argument here. Arguing that the current tax policy, and previous tax cutting policies (often correcting bracket creep an vast government expansion) push us too far to the side of the Laffer Curve. Yet, I've just demonstrated that following all of these tax cuts, revenues increased (in constant dollars).
Well, rest assured, you're going to get a Republican House or Representatives pretty soon after this Presidents first midterm election as well. And maybe they can establish some fiscal responsibility in the coming years as they briefly did last time. Also, Clinton did sign some bills LOWERING taxes during his second term.If the tax cuts expire, we go back to the rates we had during the Clinton years. Ah, if only we could have it so good.
And this still avoids the illogical decision to RAISE taxes during an economic down turn. The high-tax arguments are economically illiterate even during economic healthy times, but to do so right now, is either ignorant or deliberately destructive.
And Obama has expressed his real tax policy during the primaries.
When addressing the economic REALITY that reducing the capital gains tax generated MORE revenue, both under Clinton and Bush, Obama argued that he supported raising them in the name of "fairness" despite the decreased revenue.
YouTube - Obama: Raise Taxes, Capital Gains - "For Purposes of Fairness"
Taxes are among the reasons companies move overseas.Companies aren't shipping jobs overseas because of taxes. They're shipping them overseas because they can. There is no tax break that can possibly make an American worker competitive against a Chinese or Indian worker making $5 a day.
And tax reform would be something that stimulated companies to refrain from outsourcing, as well as stimulating other companies to in-source production to this country.
Regulation is another problem problem.
And political uncertainty, particularly with this administration and their overt hostility to capitalism is another.
Here are the numbers I used for reference:
http://www.taxpolicycenter.org/taxfacts/displayafact.cfm?Docid=200
