Using a larger Maf has its place. On a stock mark its not a performance upgrade. I get that. The larger maf has less sensitivity. Volts per cfm of volume. If a maf flows 500 cfm and a larger maf flows 1000 cfm but the engine only flows 470 cfm @ 6000rpm. Then the smaller maf per .1 volt should be close to 10 cfm. The larger would be .1 volt to 20 cfm, much less sensitive. This is why the ecu would need to be tuned to know that the maf has a larger opening. The air speed is slower due to the larger maf housing.
Is that getting close to how it works?
You are getting at it... but what a larger maf does is exactly what you DON'T want... you want to use up as much of the MAF's resolution as possible, like I said I can hit .85 load numbers out of a possible 1.00......
Here is the stock Mark MAF transfer... if this means anything to you
1023.9844 0.0000036336 5.000, 47.705
1023.0000 0.0000036336 4.995, 47.705
980.0000 0.0000031916 4.785, 41.903
920.0000 0.0000026445 4.492, 34.720
870.0000 0.0000022445 4.248, 29.468
820.0000 0.0000018915 4.004, 24.834
780.0000 0.0000016405 3.809, 21.539
740.0000 0.0000014091 3.613, 18.500
700.0000 0.0000012089 3.418, 15.871
660.0000 0.0000010305 3.223, 13.530
620.0000 0.0000008726 3.027, 11.457
580.0000 0.0000007334 2.832, 9.629
540.0000 0.0000006114 2.637, 8.027
500.0000 0.0000005048 2.441, 6.627
460.0000 0.0000004084 2.246, 5.362
420.0000 0.0000003325 2.051, 4.365
380.0000 0.0000002617 1.855, 3.436
340.0000 0.0000002063 1.660, 2.708
300.0000 0.0000001602 1.465, 2.103
280.0000 0.0000001397 1.367, 1.834
260.0000 0.0000001211 1.270, 1.590
240.0000 0.0000001043 1.172, 1.369
220.0000 0.0000000894 1.074, 1.174
200.0000 0.0000000759 0.977, 0.997
160.0000 0.0000000522 0.781, 0.685
140.0000 0.0000000428 0.684, 0.562
120.0000 0.0000000345 0.586, 0.452
100.0000 0.0000000275 0.488, 0.361
0.0000 0.0000000000 0.000, 0.000
