htrdlincoln98
Well I maybe selling a set up shortly. All I know is its cold, real f ing cold.
You need to understand 2 things... an engine has an ability to pull in xx amounts of air... what mods like cams/exhuast/etc do is increase the efficiency of the motor using xx amounts of air...
The only mods that increase the amount of air that can go into the engine is boring and stroking... aka increasing displacement... Or if you run the engine up to a much higher rpm.
So yes if you built a 5.0+L 4v and revved it to the moon you might need a bigger maf... but no 4.6 4v needs a bigger maf.
Food for thought: My Mark pulls a MAX of about .850's load.... my Vic can pull .900's or so... that being said the Vic is using more of the maf's resolution which is a good thing... I would love to see my load numbers peaking at .950-.980... that would be awesome...
Engines have this thing called Volumetric Efficiency (VE) There is another way to to get more air into the engine....Porting the heads for one and of course there is forced air induction, (turbo, supercharger)
If you looked at the Marks base fuel table you would realize that it needs less fuel, EVERYWHERE...
In my first two sentences I mention VE... and porting doesn't increase the amount of air the combustion chamber can hold, it increases VE...
Also you mention moving the IAT to get more fuel... this is an absolute hack way to get more, ummm, power?
GTFO with your klingon hieroglyphics (sic).86λ Ftw!
True story, it will increase how much air fills the cylinder..VE......If I had a fuel table I would look at it. What is wrong with hack? If it works I see no problem. There are no rules that state u must do things according to whom or whoever..........So tell me great one, how then and by what rule do I lean out the fuel table EVERYWHERE?
By the way, mine is a 93 Mark 8. Do the fuel tables run about the same?
FLTRX; said:573609 Which chip do you recommend?
