mclare mirror
Quik LS said:
I purchased :
- 12,000mcd RED LEDs off e-bay (100 LEDs for $18)
- 560ohm resisters from Radioshack
I then
- soldered 9 LEDs in parallel into a V and attached a resistor to one leg
- covered them in glue to keep it water tight
- pulled the mirror out of the housing
- pulled the mirror out of the plastic holder
- peeled the heater pad off the corner of the mirror (and cleaned the glue goop off the mirror)
- cut enough of the plastic housing away to mount the LEDs
- filled the cavity with black silicon sealant (to keep it water tight)
- attached the LEDs to the turn signal wires (already in my mirror from my earlier project)
took a couple of hours - but pretty easy.
looking for the 12000mcd lights on ebay they only have white can i use the 11000 or anyother ones, also can you let me know where you got the clear plastic blinker material
itsnotmydaddys said:
will the 11000 work theyre liek 10 bucks cheaper and buy it now now cheaper, do you have the intructions for installing them,
yep - a little dimmer - no big deal.
