He's just gonna keep overheating his engine trying that test. I would do the radiator hose thing first.That'll make SURE you don't have air in it. don-ohio^)
Doesn't matter. It is a test to see if the system can hold pressure. If it can't, bleeding is unlikely to ever work.
I just did both as suggested. The upper radiator hose is super hot. Doesn't feel very firm. I can squeeze freely on it (doesn't seem like very much coolant is in there)....
Fair enough. Would a pressure test discover the leak you think? Would it be wise to replace the bottle again?
Sent from my iPhone using Tapatalk
... What is your reason for wanting the DATC off (and the DCCV closed)?
