GMAN
Will someone with this water pump post up some pics of their wiring? I would like to see some examples. Thanks.
I've been hesitating putting it on. Since I don't race my car, are there any advantages to using it?
Greg, how many Marks have you owned? Out of all of them, have you had one overheat because your water pump wasn't good enough? I never have and I'm just as far down South as you. I have only had to replace one water pump out of three Marks but even with the bad one that was squealing like a stuck hog, it still kept the engine cool.
I am mainly curious as to where everyone is accessing the trigger.
It looks like you have the green wire going to three locations in the fuse box?
No, I just used a section of green wire to extend the orange wire (constant hot). It's wired to a constant hot. The other green wires that comes into the box green goes to a switched hot connection. There is just a bunch of extra wire in there since I just stuck it in temporary for testing.
If you look carefully, the orange wire changes to green and runs straight up to where it is directly plugged in to the open slot (the one with the fuse missing).
The switched wire is green all the way and very long and I have it looped a couple of times before hooking to the last 20A fuse by the hinge of the cover. It's just looped between the 30A and the 20A, not hooked to anything.
OK, I see. You didn't get your hot directly from the battery.
Guys Guys... Don't take this the wrong way but come on now! Cleary you have the ability and the knowledge to install and make the pump work among other things. I hate seeing wires run in and tapped into fuse locations. Worst invention ever was a fuse tap btw.
Take the time to find a wire on the fused side of the fuse, not the feed side; unbolt the fuse box and tap into the wire properly.
I know sometimes we just need to get stuff done but I've seen way to many bad things happen with poor electrical connections in cars, I did custom installs for years and you wouldn't believe some of crazy stuff people do... Well some of you would.
FWIW, my hookup is only temporary to see if it was going to work ok for a DD, and I didn't put the wire on the fused side (obviously since in the pic you can see the fuse isn't even in where one wire is plugged in). Since it has an inline fuse, I figured I could hook it straight.
So far, the cooling is NOT sufficient in my case - car runs hotter than before and if I hot-rod it, the temp climbs steadily. I'm going to try a high-flow 180* t-stat first, then prolly go with a Cobra radiator afterwards. Those are the mods it took in my TBird to get it to run cool (it's hot here).
Did it run hot with the factory WP? Is the radiator still the original now?
I've looked at the cobra radiators and the I can't tell if the cobra replacements are all aluminium or plastic tanks. I know I can get a becool or others.. but they are proud of them.
I know its taller but I could notch the lower panel to get it into the same location, I need the space infront of the motor for the snail and pipe.
Where and what did you get for your bird?
