10inches
Does a 94 Mark VIII come with a steel crank, and is it a 6 or 8 bolt pattern?
Thanks
Thanks
I was also told that some of the cast cranks had 8 bolts.
10inches said:My question was directed toward the crank not the mains. I have found conflicting information as to whether the crank is steel or cast.
evillally said:That would be the 4.6L SOHC Mustang GT crank.
Thanks for the info, I just worded my question wrong, wasnt sure if they were forged or cast. I have a project Im working on and prefer a forged crank however, I have found 3 wrecked 94 Mark VIIIs that I can get the motors from very cheap. According to a few sources these cars have the Teksid block, which I understand to be the one desired by most.Dern Humpus said:It is both. Cast steel. You can have a forged crank or a cast crank. It is cast steel.
