Motor Question
My question was directed toward the crank not the mains. I have found conflicting information as to whether the crank is steel or cast. I was told that an easy way to tell was if the crank had eight bolts it was steel and if it has 6 it is cast and that not all Mark VIII had the same crank. I was also told that some of the cast cranks had 8 bolts. All of your help is apprectiated but I was looking for some definitive answers.
Thank You for all the responses
It is both. Cast steel. You can have a forged crank or a cast crank. It is cast steel.
Thanks for the info, I just worded my question wrong, wasnt sure if they were forged or cast. I have a project Im working on and prefer a forged crank however, I have found 3 wrecked 94 Mark VIIIs that I can get the motors from very cheap. According to a few sources these cars have the Teksid block, which I understand to be the one desired by most.
