My cruise control won't work any suggestions
Briansls
boston
I have an 01 Lincoln Ls and I put an aftermarket radio in and now my cruise control and radio buttons don't work. I now I need a module for the radio controls but will that also make the cruise work. Im not sure any suggestions would be greatly appreciated.
Did you connect the two wires from the steering wheel controls to anything? If so, disconnect them, that might be the problem.
+2 clockspring
+2 clockspring, also the radio controls might not work correctly.:D
I couldn't get my cruise to work either just before I put it away. Car has a new clockspring and everything else on the wheel works fine. I am pretty sure I checked the fuse as well but I am not certain. I will have to check it again when I pull the car out.
I couldn't get my cruise to work either just before I put it away. Car has a new clockspring and everything else on the wheel works fine. I am pretty sure I checked the fuse as well but I am not certain. I will have to check it again when I pull the car out.[/QUOTE
Do you now were the fuse for the cruise is located?
I would think in the dash fuse panel? I haven't worked on the car enough to know this stuff off the top of my head yet. I just changed oil on it and the wife drove it all the time.
Someone else I am sure will have an answer.
