My door wont lock with the keyless remote.
Alax7
LA
I just noticed the driver side door wasn't opening or locking with the keyless remote, auto lock, or the open/lock button in the car. The other side works fine. I hear a little click but nothin happens. I took the door panel off but dont know what I'm looking for. Could it be a fuse? I would think a fuse would be connected to more than just that lock, but I'll check them either way. Any guess?
It also feels like the lock might be jammed. It doesn't lock into place.If the motor isn't working, would this prevent it from locking manually?
Mine was acting up about a year ago.. I just locked and unlocked it a few times then the power locks started working again... Sorry I didn't dig into it so I don't know what you should look for.
Alax, put the door panel back on, this is WAY over your head. Check the tire pressure, maybe that will help.
Sounds to me like that actuator is bad. They are usually pretty cheap and really dont take to much to put in.
+1 sounds like something is jammed if you cant lock it manually.
Hey thanks fordfan.Yeah I'll do that right now fordfan thanks for your common sensem, should I sell my ls now before it breaks down more or later? NO! :bash: ..... Hell no!!!! How am I suppose to learn if I dont dig into it.I'm trying, just dont want to tear the whole door apart when it was a little piece that was broken and easily replaceable with just the panel off.
At first it would lock but when I took the panel off and tried locking it it wouldn't lock.Dont know what an actuator is, but I'll look into it.Thanks.
you're very welcome!!
You can only give common sense to someone who is capable of common sense, and is willing to listen.
You are not capable of either.
The actuator is the device that actually locks the door, kinda like a little electric servo or motor. It usually has a small rubber boot similar to a cv boot on a front wheel drive car. Since I haven't had the LS door apart, maybe it looks different but I doubt it. Good Luck
i believe this would be your problem they work like a solenoid and i know they were out sometimes. they only thing is that you say its hard to lock manully meaning jammed so maybe the coil in side of it is melted somehow like what happens to electric motors its similar in construction only diff is lateral motion instead of rotational....
Actually I do listen, and I would listen to you, IF you actually gave REAL advice or atleast attempted to but you just gave me a dumb response and said dont even try, you're incapable of fixing it.You're partially right, I dont listen, but only to you because I am open to advice and criticism to does who actually give it.
Oh ok, got it. Thanks.
Thanks joe. Now I know what I'm looking for
Hey Alax, just do what I do. Use the ignore feature on him (fordfan). It cuts down on the BS you read on here.
i had to take him off of the ignore list to see what he would say about the STFU thread and now he's back on it
Yeah, I was thinking of doing that. Didn't want to cause you never know what insight people might have if you block them, but this guy is going there soon
I had this exact same problem a year ago. Locks wouldn't work with the remote or door switch. I could also hear the faint click. I replaced the latch assembly which includes the motor. Problem gone. I bought the part from a forum member who was parting out a car. Dealer was no help. They couldn't even find the part. They told me I had to replace everything in the door at a cost of $600.
I actually had the same problem on my driver's door when I bought my LS. After using the key to manually lock/unlock the door for about a week, it fixed itself and has worked fine ever since. I went to the local ford dealership near me and it was going to run me about $125 for a new actuator. Glad I didn't waste the money since it fixed itself.
I have GREAT NEWS....well to me they were. I fixed it!! I called 5 star ford and they gave me a price of 235 for a new one. I called local junk yard 25 minutes away, 100 bucks. So I took the actuartor off finally after trying for about half an hour, so simple just couldn't see with there being limited space between the door. Took it off, took it apart to see why it wouldn't lock anymore. I also tried testing the motor to see if it was the one that wasn't working. I took the motor off the actuator and it worked. So then I thought It was the connector that goes into the actuator so I connected it and now the motor worked. Put it back together and it stopped working right away. Finally figured it out. There was this little piece that is held by a clip that moves back and forth when you lock it. This came out and when I locked it it got stuck in the path of the part that moves back when you lock it. This caused the motor to get jammed, that's why it worked when I took it off, because it wasn't under the jammed pressure. Popped this piece back in place and made sure it was held in and it worked like new. Getting a new actuator would've solved the problem because this parts would be held in place in the new one. Nothing was broken. I think this might be what happened to a few people who had similar things happen with their lock and getting a new one solved the problem but there would work fine, it was just jammed. For future reference to whoever it happens to next. Take the whole actuator apart and check it, save yourself the money and learn how the locks on your car work. I'm stoked right now :D
Oh and #1fordfan, GO SUCK MONKEY BALLS B**CH!!!!!!!!! I just did what you said I couldn't and was too dumb to do on my own, plus I actually found the problem and fixed it not just swaped in a new one jst to get rid of whatever the problem was.
Oh and now that I know how to take off the door panels and all the other things i think I could go back in time and fix it in about 20, including taking and ptting back everything like it was.
Oh and #1fordfan, GO SUCK MONKEY BALLS B**CH!!!!!!!!! I just did what you said I couldn't and was too dumb to do on my own, plus I actually gfound the problem and fixed it not just swaped in a new one jst to get rid of whatever the problem was.
Nice job Alax, you gfound the problem and swaped (whatever that means) jst to get rid of the problem.
ptting it back together was a stroke of genuis!!! (whatever that means)
instead of LSOFM, maybe you guys should have a LSMOTM.
(the first M is for mechanic)
Instead of just swaping, meaning I fixed the problem and used the original part instead of replacing parts until the problem was fixed. Instead of guessing and putting new parts in, I fixed what wasn't working.
So much for common sense.
Oh my, I will slow down for you. swape, swaped, and swaping are not words in the English language.
you might have meant "would not have" instead of "would've worked" in the original post.
I am pointing out you lame attempt at the English language, not your lack of common sense. That speaks for itself.
What is "you lame attempt at the English language"?
You FAIL.
