Hi Jager, yes thank you I meant p0420......ok gottcha....when your referring to "misfires" because of "COPS" whatis it exactly you are are you referring to?
Ls guy.
Hey Jager, thank you again. Sorry should have nmentioned, 2002 LS...130 kilometers, v6.
Hey Kingtonghsp, thank you for the info.....would it cover an 02? Anyway I can check?
Stay safe in Afgan country!! Have you met up with Canadians there?/QUOTE]
Extended COP warranty only covers 2003-2005 years, 10 years/100k miles.
The four biggest possibilities are:
1. Your right side catalytic converter is failing. (If so, this is probably because of misfires because of marginal COPs.)
2. You have an exhaust leak on the right side.
3. Your right rear O2 monitor is bad.
4. Your right front 02 sensor is bad.
(Note: I assume that you meant code P0420.)
well i thought it was the left side?? mine said the same thing and i took it in and it came out to be the left side which is driver side
I'll wait for others to chime in.
My thinking is that cylinders 1 to 4 are bank 1 and they are on the right (passenger's) side of the engine. Cylinders 5 to 8 (bank 2) are on the left (driver's) side.
ok am 99.9% sure its the left side and you also need to change your sensor also...like i said mine was the same and it came out to be the left side but i have 03 lincoln ls i dont know is that will make a difference
Well, I'm confused then. My searches of Ford documents and of this site all say that bank 1 is the passenger side. Are you sure that you didn't have a P0430 code, which would be bank 2, the driver's side.
I had to find cylinder 7 once due to a misfire. It was on the driver's side, bank 2.
how about why does he keep calling Joe, Jager?
Thanks guys for al your imput and interest. I cleared the check engine light, scanner, and checked again..of course a couple of lights were blinking. I think it said could not complete all tests yet, yellow light. If I recall it was emission related.
Check engine light is still off and I get a green light now with nothing blinking. So I reckon all is well???..hopefully???...
Also re backfires & coils...I have only owned it a short time...no backfires showed up on scanner...I haven't heard or felt any.
I do want to tune it up however.....including plugs and coils....anything else I should make sure the mech does re tune up that is ls specific?
Thanks again!
ps....I appolgize Joe......realize I refered to you as Jager .
