true, I am happy with what I have. How do i go about hoking subs to it? is there a plug n go? where is it located?
What all would I need for a 12" and an amp? Theres a factory amp b sub how can I keep that n addmore
ok so there is really two ways to do this right
I'll try to keep it as simple as possible
you will need a box, sub or subs of your choice, an amp matched to that/those specific sub/s. and an amp kit.
the right amp kit will have a power wire with fuse, a ground wire, a RCA cable, an amp turn on wire, and some speaker wire.
first, tape the RCAs and the turn on wire together
remove the radio
connect the RCAs to the
SUB PREOUT or
SW OUT
then connect the turn on wire to the amp control wire coming out of the pioneer radio (blue/white)
the put the radio back in (take care to leave a few inches of cable behind the radio so the radio can still be pulled out later if needed aka do not pull the RCAs as tight as possible)
run those wires into the trunk
mount the amp somewhere, most people screw it to the back of one of the seats.
connect the RCAs and the turn on wire to the amp.
run the power wire with the fuse from the battery's positive terminal to the amp, cutting off any extra wire (making sure to put the fused end near the battery)
then either take the ground wire and connect it to the amp, scrape off some paint on a suitable spot on the body, and screw the ground wire into the metal body where the paint was removed (dont half ass it here, there needs to be bare clean metal where the ground wire screws to the body) (also make sure not to drill through anything important)
OR my favorite
take the extra power wire that was cut off (as long as it is long enough, which if it ain't, you probably ran the power wire wrong to begin with...) tape a couple inches of each of its ends black, then use this as the ground wire, running from the amp all the way to the battery's negative terminal (right along side the power wire)
install the sub into the box, connecting the wires from the box's terminals to the sub's terminals.
then run speaker wire from the amp to the sub box
then just adjust some knobs, set some settings, be done crack a cold one and enjoy it
OR just take it somewhere and pay to have it done.
