ToddG
I need to get a new battery. Any suggestions?
ToddG said:Thanks for the suggestions.
Picked up a CR2032 lithium battery at Radio Shack. My remote works great now!
Hawk03 said:I got mine at the dealer as well, $110. It was a non-vented one, they said the batteries have been redesigned and it didn't need to vented.
LS4me said:Yet another stupid dealer parts guy. I got mine about a month ago. The guy made sure it was the vented type. EVERY battery gasses. Even the Optimas.
ToddG said:Sorry guys, just having a little fun with ya!
Seriously, the dealer parts person selling an unvented battery is a bit surprising. Makes me wonder that if what he says is true, what type of battery are the putting in the 2006 LS? Is it vented??
Quik LS said:we must use a 'vented' battery since the battery sits in the trunk and shares air-space with the passengers.
I beleive the 750amp unit is $89 - which is not a bad price (imho)
adding $50 to swap it is silly - is takes 5 mins and a 8mm socket.
Quik LS said:local LM dealer. One thing to check - many LSes came with a 650amp stock - but the 750amp is the same size and not much more $$$.
the Optima design makes it leak proof and can be mounted in any position - but it still vents gases as it recharges - so you should not use it with out an additional vented battery box (Optima says in 'usual' use it should not emit gas but can).
I kill my battery so often - that I am think of going that route as well - but I have not sized the battery box yet.
Quik LS said:the Optima design makes it leak proof and can be mounted in any position - but it still vents gases as it recharges - so you should not use it with out an additional vented battery box (Optima says in 'usual' use it should not emit gas but can).
SALVAGE LS said:Just wondering where this vent is. I had my battery changed to a yellow top and havent had any problems with it. Its basicly sealed in the truck anyway right.
beaups said:I just bought one from the dealer, $99 and its vented. Several threads on this but I do recall seeing that the optomas DO vent. And no, the trunk is not sealed from the cabin. If it was that would probably be even worse as the gasses would build in the trunk. Get the right battery.
