94m5
Dmaup's Daddy
Ed, I don't want to see one more reference to your idiodic towing experience. Either drop it or leave.
ed, i don't want to see one more reference to your idiodic towing experience. Either drop it or leave.
R-lincoln, you are not going to lose anything with 18 as you need to replicate the hieght of stock so the car knows what is going on. You can do 20s on the car as long as your hieght is close you will be good.
Stock 3.27? I thought your car was a base?31 mpg from sacramento to portland including climbing the passes and a couple minutes screwing around with a z28 (this was with the stock 3.27s)
You nees an MSD tach driver. Why do you need a tach?
Man I wish I 10k to hook up my ride, must be nice.
jmod. dual exhaust. 4.10 gears and trac lok. high stall torque converter. tune. run low 14s. maybe high 13s?
High 13's?? LOL Better be better then that with all that man. Gen 1's run 14.60's stock and Ken has gone 14.33 with just a cat back.
really that quick? to bad test and tune nights are over here in ontario cuz i'd be taken the mark for some base test runs in this form, if i could get car into 12's one day that would be perfect
