jays94mark
this is an issue that started with prior owners , if you use the power lock button,fob,or keypad to lock the car after 30 seconds or so the horn starts sounding and lights blinking as if the alarm was tripped , ive tried the wd-40 the door switches like the dealship said to try , but no luck , my car is a 1994 mark 8 basic with moonroof , i need help to fix this or locate the source of this problem any idea's ????? (also if i lock the car manually by just pushing the lock buttons down its fine??)
