I cant get the caliper to compress i used a c clamp to try and compress it, but nothing is there a special way to do this if so let me know. I need it done asap. I already tried to search but nothing. Thanks
autozone and a few others rent you the tool for free. go get it, makes the job a real breeze.
Just curious, are front brakes the same way or do you use a c-clamp to compress the piston?
c clamp works fine on fronts...
