Hahahahaha. I'm not even done yet. Still have to do underdrive pullies, throttle body, IMRC deletes, take some fuel out of my tune and knock the shift points down to about 6700 rpms. It's a turd yet. I suppose I should probably replace my original 165K mile fuel pump while I'm at it too and my original ignition coils. I'm going to be working on a racing seat setup too eventually here unless the motor decides to blow before then. By then, I'll be low 13s. I won't run 12s like Frank. This engine is too worn in and it makes noise. Hell, if I can make some ends meet I might even run it this October after I hit the dyno and get the AF ratio where it needs to be and the shift points not at 7100 rpms and see if I can crack 13.4xxxs before I even do all the rest of that stuff. Then I know it will only go deeper.
Unfortunately, stripes are not on my list. I guess I'll just have to deal....
