If you decided to swap headlights you would need to get the 03 and up light brace that goes underneath the bumper. The mounting points on the 00-02 headlights are different than that of the 03+ headlights. The brace is around $150. Do a search on LvC for this. It has been done. However, you'll need to re-wire the headlight wiring harness because those are different too.AnderbrA said:So swapping the headlights out will resolve the gap issue? Do they use the same mounts?
