Today's Daily special (April 5, 2013) is DI Microfiber Micro-Restore Microfiber Detergent Concentrate.
Regular Price for 32 oz is $14.99. Today's price is $10.64!
Regular Price for 128 oz is $34.99. Today's price is $24.84!
  • Microfiber, cotton, chamois and towel revitalizer
  • Breaks down heavy wax, oil and grease
  • Contains no bleach or fabric softeners
  • Use 2 ounces for full loads or 1 ounce for smaller loads
  • Biodegradable
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (April 8, 2013) is Optimum Opti-Lens Coating.
Regular Price for 10 cc is $59.99. Today's price is $45.00!
  • Easily protect your headlights from fading, yellowing, hazing, and road grime
  • Keep your headlights crystal clear for optimal clarity while driving
  • Unique resin based formula that bonds to the surface of your headlights for durable protection
  • Easy to apply to any smooth plastic surfaces
Today's Daily special (April 9, 2013) is DI Brushes All Purpose Exterior Brush.
Regular Price is $4.99. Today's price is $3.69!
  • Use it to safely clean the exterior of your vehicle
  • Soft and safe to use on various surfaces
  • Flagged-tip bristles are resistant to acids and detergents for added longevity
Today's Daily special (April 10, 2013) is Lake Country Yellow Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $7.99. Today's price is $5.91!
Regular Price for 4 inch is $4.99. Today's price is $3.59!
Regular Price for 3 inch is $3.99. Today's price is $2.97!
  • The most aggressive foam cutting pad, designed to remove the deepest swirls and scratches
  • Medium to heavy cutting polishes work great with a yellow cutting pad
  • We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
  • You need to follow up with a lighter pad and polish combo afterward to remove haze on the surface
Today's Daily special (April 11, 2013) is Meguiar's Professional DA Polisher Backing Plate W67DA.
Regular Price for 5" is $19.99. Today's price is $15.53!
  • Soft core foam allows for easier maneuverability compared to stiffer backing plates
  • Works with any polisher with a 5/16th shaft (such as the Porter Cable 7424XP)
  • Durable one piece construction ensures a long life
  • Works best with 5.5" pads or larger
Today's Daily special (April 12, 2013) is DI Microfiber Autofiber Pocket Towel.
Regular Price for 16" x 16" is $5.99. Today's price is $4.43!
  • Great microfiber towel with a unique paint safe design
  • Two large pockets help keep your hand in place while working side to side
  • Pockets helps protect your hand on both sides
  • Can be machine washed and dried
  • Saves you time while improving your results!
Today's Daily special (April 15, 2013) is Lake Country Detailing Stick.
Regular Price is $1.99. Today's price is $1.45!
  • Excellent tool for cleaning tough to reach areas
  • Rinse and re-use these sticks over and over again
  • Great tool for the front grill, exterior trim, engine bay, lug nuts, door jambs, side mirrors, etc.
  • Remove tough stains with the Lake Country Snappy Clean Pad Cleaner
  • Durable foam tip with 8" wooden handle
Today's Daily special (April 16, 2013) is Meguiar's Pad Conditioner Brush.
Regular Price is $13.99. Today's price is $10.35!
  • Helps remove excess product trapped in your buffing pad
  • Helps keep pads working in ideal condition
  • Safe on all foam pads and very easy to use!
Today's Daily special (April 18, 2013) is 303 Aerospace Protectant Wipes.
Regular Price is $7.99. Today's price is $5.95!
  • A convenient way to apply valuable UV protection
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • 40 Aerospace Protectant Wipes come in each bottle
  • Treated surfaces resist dust, soiling and staining plus it helps repel moisture
Today's Daily special (April 19, 2013) is DI Microfiber Black and Yellow Towel.
  • Two sided towel that is perfect for cleaning inside and out
  • Plush on one side with a shorter nap on the other
  • Tag less design with bounded edges for added durability
  • Safely and easily removes polishes, sealants, waxes, etc.
  • Can be cleaned with the Micro-Restore Microfiber Detergent Concentrate
Today's Daily special (April 22, 2013) is DI Accessories DetailedImage.com License Plate Frame.
Regular Price is $5.99. Today's price is $4.25!
  • Black DetailedImage.com license plate frame with white lettering
  • "Clean Shine Protect" tag line
  • Thank you for your support!
Today's Daily special (April 23, 2013) is Meguiar's DA Microfiber Correction Compound.
Regular Price for 16 oz is $18.99. Today's price is $14.15!
Regular Price for 32 oz is $34.99. Today's price is $25.54!
Regular Price for 128 oz is $84.99. Today's price is $63.32!
  • Superior cutting power that finishes down smooth and glossy in one step!
  • Use with Meguiar's Microfiber Cutting Disc Buffing Pad and a Porter Cable 7424 XP for best results
  • Revolutionary new technology that will forever change detailing!
Today's Daily special (April 24, 2013) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.79!
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Today's Daily special (April 25, 2013) is CarPro Iron X Iron Remover ( IronX w/cherry scent ).
Regular Price for 500 ml is $19.99. Today's price is $15.20!
Regular Price for 1000 ml is $32.99. Today's price is $25.08!
Regular Price for 4 L is $99.99. Today's price is $85.00!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
Today's Daily special (April 26, 2013) is DI Brushes Leather and Vinyl Scrub Brush.
Regular Price is $3.99. Today's price is $2.91!
  • Outstanding leather care brush to deep clean leather!
  • Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
  • Soft and gentle leather brush that works great
Today's Daily special (April 29, 2013) is DI Accessories Universal Replacement Flip Top Caps.
Regular Price is $0.75. Today's price is $0.56!
  • Universal top that fits the majority of 16oz, 32oz, 500ml and 1000ml bottles
  • Spout helps control how much you pour out
  • Helps conserve product and save you money
  • Keep a few around the garage in case you break a cap
Today's Daily special (May 1, 2013) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6 inch is $11.99. Today's price is $8.75!
Regular Price for 5 inch is $9.99. Today's price is $7.09!
Regular Price for 4 inch is $5.99. Today's price is $4.79!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (May 3, 2013) is DI Accessories Razor Blade and Mini Plastic Holder.
Regular Price is $1.99. Today's price is $1.41!
  • Pocket size plastic scraper with one single edge razor blade
  • Quickly remove inspection stickers and registration stickers
  • Use for virtually any scraping, trimming, or cutting
  • Open or close with easy push button lock system
Today's Daily special (May 6, 2013) is Surbuf R Series MicroFingers Buffing Pads.
Regular Price for 2x 6.5" is $16.99. Today's price is $12.57!
Regular Price for 2x 5.5" is $13.99. Today's price is $10.21!
Regular Price for 2x 4" is $9.99. Today's price is $7.29!
  • Excellent polishing power with minimal haze left behind!
  • Read a professionals recommendations on how-to use Surbuf pads properly
  • Each box comes with 2 pads
  • The pads can be washed and re-used many times
  • Perfect match for Porter Cable users with Meguiar's M105
Today's Daily special (May 7, 2013) is DI Accessories Razor Blade.
Regular Price for 100 pack is $6.99. Today's price is $5.03!
  • 100 pack is an awesome value!
  • Fits all standard razor blade holders
  • Made in USA high carbon steel
  • Quickly remove contamination, stickers, etc.
  • Single edged design
Today's Daily special (May 8, 2013) is Chemical Guys Luber.
Regular Price for 16 oz is $9.99. Today's price is $7.29!
Regular Price for 128 oz is $29.99. Today's price is $24.92!
  • An outstanding clay bar lubricant formulated to work specifically with your clay bar
  • Can also be used as a quick detailer to remove a light dusting along
  • Works great with the Chemical Guys Fine Grade Clay Bar
Today's Daily special (May 9, 2013) is Little Trees Royal Pine Air Freshener.
Regular Price is $0.99. Today's price is $0.71!
  • The original Little Trees scent that is still a favorite
  • Proudly made in the USA
  • Great scent that lasts several weeks
Today's Daily special (May 10, 2013) is DI Accessories Plastic Razor Blade.
Regular Price is $0.99. Today's price is $0.72!
  • Perfect to use on windows!
  • Quickly remove inspection stickers and registration stickers!
Today's Daily special (May 13, 2013) is Little Trees Wild Cherry Air Freshener.
Regular Price is $0.99. Today's price is $0.74!
  • A great cherry scented air freshener that everyone will love!
  • A fun and pleasant scent that easily lasts several weeks
Today's Daily special (May 14, 2013) is Lake Country Blue Grout Sponge.
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
