Today's Daily special (December 18, 2014) is Chemical Guys Water Spot Remover.
Regular Price for 16 oz is $18.99. Today's price is $13.48!
  • Easily remove light to medium watermarks and mineral deposits from your paint, chrome and glass
  • We recommend using a foam applicator pad along with some elbow grease for application
  • Faster than the traditional polishing process
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (December 19, 2014) is Tuf Shine Tire Appearance Kit.
Regular Price is $39.99. Today's price is $29.19!
  • The first ever semi-permanent tire dressing that looks amazing and truly lasts
  • One coat rich and dark finish, two or more coats is extremely glossy
  • Contains no oils or silicone's that can harm the tire
  • Will not sling off, dries to the touch in minutes and applies with ease
  • Tires look stunning and do not feel greasy or oily at all
Today's Daily special (December 22, 2014) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $7.99. Today's price is $5.91!
  • Easily kill water flow with a simple twist of a knob instead of walking back to the hose source
  • Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Today's Daily special (December 23, 2014) is DI Accessories Yellow Foam Applicator Pad.
Regular Price is $1.49. Today's price is $1.11!
  • Most commonly used for applying polishes, glazes, sealants, and waxes!
  • Helps you apply a thin and even coating over any surface for maximum results
  • Washable and reusable so they provide a great value for years to come
Today's Daily special (December 29, 2015) is DI Brushes Vent and Dash Boar's Hair Detailing Brush.
Regular Price is $9.99. Today's price is $7.09!
  • Perfect brush to clean around hard to reach interior surfaces
  • 2.5" long bristles made of soft natural Boar's Hair
  • Handle made of high quality durable ferrule
  • Easily clean buttons, nobs, vents, radios, speakers, seams, crevices and more!
Today's Daily special (December 30, 2015) is Dodo Juice Light Fantastic Soft Wax.
Regular Price for 30 ml is $13.99. Today's price is $9.93!
  • A Dodo Juice soft carnauba wax designed to work exceptionally well on lighter colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Can be applied with a foam applicator pad or literally with your bare hands
  • Dodo Juice soft waxes offer slightly more depth and gloss over the Dodo Juice hard waxes
  • Remove any Dodo Juice wax with a plush microfiber towel
Today's Daily special (December 31, 2015) is DI Brushes Foam Pad Cleaning Brush.
Regular Price is $1.99. Today's price is $1.45!
  • Helps remove excess product trapped in your buffing pad
  • Safe on all foam pads and very easy to use
  • Helps prolong the life of pads and keep them in ideal working condition
  • 8" contorted handle and .75" nylon bristles
Today's Daily special (January 2, 2015) is DI Brushes Heavy Duty Wheel Brush.
Regular Price is $4.99. Today's price is $3.64!
  • Clean even the heaviest of build ups off your wheels quickly and easily
  • The stiff blue polypropylene bristles provide extra scrubbing action
  • With a simple rinse this brush is clean for future uses
Today's Daily special (January 5, 2015) is DI Accessories Chemical Resistant Spray Trigger.
Regular Price is $2.99. Today's price is $2.21!
  • A high quality trigger meant to withstand strong cleaning agents
  • Can spray a fine mist or a direct stream
  • Works great with virtually any bottle including the DI Accessories Trigger Spray Bottle
Today's Daily special (January 6, 2015) is 3M Automotive Masking Tape.
Regular Price for 18 mm is $3.99. Today's price is $2.91!
  • Quality masking tape for protecting your trim, paint and more!
  • Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
  • Great value!
Today's Daily special (January 7, 2015) is Chemical Guys Leather Scent.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
  • Fresh leather smell
  • Spray on fabrics or wipe on interior
  • Eliminates bad smells by breaking down odor causing bacteria
Today's Daily special (January 8, 2015) is Optimum Opti-Seal.
Regular Price for 8 oz is $24.99. Today's price is $17.74!
  • The ultimate in ease of use when it comes to protecting your vehicle with a sealant
  • Simply mist Opti-Seal onto your paint and walk away, no wiping is necessary when applied properly
  • Perfect for professional detailers or enthusiasts who are looking for maximum results in less time
  • Includes a free Optimum yellow foam applicator
Today's Daily special (January 12, 2015) is Lake Country HD Orbital Red Finishing Pad.
Regular Price for 6" is $13.99. Today's price is $10.42!
Regular Price for 7" is $15.99. Today's price is $11.35!
  • The softest of the LC HD Pads, leaves behind an incredible level of clarity with a flawless finish!
  • Pair with your favorite finishing polish
  • Runs 10% cooler than traditional Lake Country pads
  • Perfectly balanced, cushioned, and features thinner foam
Today's Daily special (January 13, 2015) is Lake Country Hydro Tech Cyan Light Cutting & Polishing Pad.
Lake-Country-Hydro-Tech-Cyan-Light-Cutting-and-Polishing-Pad-65-inch_406_1_m_2595.jpg
Regular Price for 6.5 inch is $11.99. Today's price is $8.87!
Regular Price for 5.5 inch is $9.99. Today's price is $7.29!
Regular Price for 4 inch is $5.99. Today's price is $4.46!
Regular Price for 3 inch is $3.99. Today's price is $2.91!
  • Powerful cutting action but the ability to finish down haze free
  • Hydro Tech foam keeps more polish on the surface of the pad for longer work time
  • Experience less dusting than traditional foam pads due to less product build up
  • Lake Country Snappy Clean Pad Cleaner help clean these pads
  • Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
Today's Daily special (January 14, 2015) is Chemical Guys Premium Blue Heavy Duty Wheel & Rim Cleaner.
Regular Price for 16 oz is $8.99. Today's price is $6.38!
  • Powerful and effective wheel cleaner that will dissolve grease without damaging wheels!
  • Unique non Hydrofluoric Acid formula that is safe to use on virtually any wheel surface
  • Concentrated solution makes this a great value as you can dilute it 7:1
  • No scrubbing necessary, simply spray on and wipe off
Today's Daily special (January 16, 2015) is Leatherique Prestine Clean.
Regular Price for 16 oz is $23.99. Today's price is $18.37!
Regular Price for 32 oz is $34.99. Today's price is $26.44!
Regular Price for 8 oz is $14.99. Today's price is $10.64!
  • A premium leather cleaner with light conditioners, perfect for cleaning and maintaining leather
  • Restores proteins that are naturally found in leather for a soft and supple feel
  • Completely matte finish that has no greasy or oily residue
  • Apply to your leather and let sit for 15 - 30 minutes, wipe with a warm damp towel and wipe dry with a second towel
  • For maximum results, Prestine Clean is best used after Leatherique Rejuvenator Oil
Today's Daily special (January 19, 2015) is DI Accessories Disposable Floor Mat.
Regular Price for 10 pack is $5.99. Today's price is $4.25!
  • Durable mats to help prevent adding stains to clean carpets during a detail
  • Ensure your carpets look their best when you deliver the vehicle to your customer
  • Sold as a 10 pack for a great value
  • Go the extra mile for your customers!
Today's Daily special (January 20, 2015) is CarPro Cquartz UK Edition.
Regular Price for 30 ml is $49.99. Today's price is $35.99!
Regular Price for 50 ml is $72.99. Today's price is $52.55!
  • Cquartz paint protection lasts years not months!
  • Specially formulated for cold temperature protection and application
  • Packed with 70% SiO2 with 99.9% purity!
  • Protects your paint, glass, wheels, plastic, rubber and more
  • Easy to apply and looks amazing with a tremendous level of gloss!
  • 30ml bottle comes with 5 CarPro Suede Microfiber Cloths and an applicator pad
  • 50ml bottle comes with 5 CarPro Suede Microfiber Cloths and an applicator pad
Today's Daily special (January 22, 2015) is Lake Country Tire Dressing Applicator.
Regular Price is $2.99. Today's price is $2.12!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (January 23, 2015) is Tuf Shine Tire Brush.
Regular Price is $4.99. Today's price is $3.59!
  • Great for deep cleaning the tires
  • Use with the TUF SHINE Tire Cleaner or your favorite degreaser
  • Strong yet gentle bristles
  • Cleaning your tires is critical before applying any tire dressing, especially the TUF SHINE Tire Clearcoat
Today's Daily special (January 26, 2015) is DI Accessories Sheepskin Wash Mitt without thumb.
Regular Price is $11.99. Today's price is $8.51!
  • All natural fibers makes it one of the safest wash mitts on the market
  • The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
  • When done rinse any contamination away using free flowing water than hang dry with leather loop
  • Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
Today's Daily special (January 28, 2015) is DI Brushes ATLASTA Soft Tip Brush.
Regular Price is $14.99. Today's price is $10.79!
  • Versatile brush can be used on your interior or exterior surfaces!
  • Packed with soft filament bristles that hold their shape
  • 9.75" long with a weight of 4.3 oz
  • Amazing brush for wheels!
Today's Daily special (January 29, 2015) is DI Microfiber Car Wash Mitt.
Regular Price is $3.99. Today's price is $2.91!
  • Excellent wash mitt that is soft and paint safe
  • Very cost effective washing medium
  • Can be machine washed and dried afterward
  • 1000 GSM
Today's Daily special (January 30, 2015) is Chemical Guys Metal Wax.
Regular Price for 16 oz is $13.99. Today's price is $9.93!
  • Enhances the shine and appearance of any metalwork!
  • Ideal for protecting chrome, stainless steel, aluminum, copper and clear coated metal surfaces
  • Easy application gives you great results in less time
  • Natural carnauba and synthetic polymers with UV protection
