Today's Daily special (May 5, 2015) is Chemical Guys Hybrid V7 High Gloss Spray Sealant.
Chemical-Guys-HYBRID-V7-Optical-Select-High-Gloss-Spray-Sealant-16-oz_530_1_m_3318.jpg
Regular Price for 16 oz is $17.99. Today's price is $11.69!
Regular Price for 128 oz is $44.99. Today's price is $32.64!
  • Protect your paint, plastic, rubber and more with ONE product!
  • Applies and removes with ease
  • Makes the paint look stunning while adding valuable protection
  • Many detailers love to use the Chemical Guys Black Light Hybrid Radiant Finish before using the Hybrid V7
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (May 7, 2015) is DI Microfiber Applicator Pad.
Regular Price for Rectangle is $2.99. Today's price is $1.31!
Regular Price for Circle is $2.99. Today's price is $1.31!
  • Ideal for applying a sealant or wax, can also be used for polishes, glazes and more
  • Very soft and safe applicator
  • It should last years if you hand wash the Microfiber Applicator
  • Can be used to apply interior care products like leather cleaners and conditioners, trim restorers and other protectants
  • 300 GSM and reusable!
  • Comes in two great shapes, rectangle and circle!
Today's Daily special (May 8, 2015) is DI Brushes Boar's Hair Detailing Brush.
Regular Price for 1" is $15.99. Today's price is $11.10!
Regular Price for 1.25" is $17.99. Today's price is $12.69!
  • Use it to clean your wheels, exterior trim and so much of the interior
  • Ultra soft boar's hair fibers make it safe to use everywhere
  • Very durable design and fibers so you can use this brush for years
  • Helps clean tough to reach areas safely and easily
Today's Daily special (May 12, 2015) is Menzerna Endless Shine Detail Spray.
Regular Price for 16 oz is $24.99. Today's price is $17.16!
  • Clean and protect with one quick detailer
  • High gloss and water beading
  • Protection against future contamination
  • Easy to apply
Today's Daily special (May 13, 2015) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5" is $11.99. Today's price is $7.38!
Regular Price for 5.5" is $9.99. Today's price is $6.58!
Regular Price for 4" is $5.99. Today's price is $3.84!
Regular Price for 3" is $3.99. Today's price is $2.51!
  • Bring out the maximum depth and gloss of any polish
  • Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
  • Experience longer work time and less dusting with less product absorption
  • You can clean these pads with the Lake Country Snappy Clean Pad Cleaner
Today's Daily special (May 14, 2015) is Gtechniq C5 Wheel Armour.
Regular Price for 15 ml is $34.99. Today's price is $27.96!
  • Repel dirt and brake dust from your wheels!
  • Resistant to temperatures up to 570 degrees F
  • A single application lasts up to one year!
Today's Daily special (May 15, 2015) is Chemical Guys Extreme V.R.P. Dressing.
Regular Price for 16 oz is $9.99. Today's price is $7.06!
  • Very versatile dressing that restores vinyl, rubber and plastic to a clean, low gloss finish
  • Properly protect your vinyl and rubber surfaces from UV fading with CG Extreme V.R.P.
  • To avoid over spray, we recommend misting Extreme V.R.P. into a microfiber towel to apply
  • We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Today's Daily special (May 19, 2015) is Menzerna Super Intensive Polish SI 1500.
Regular Price for 32 oz is $44.99. Today's price is $32.57!
Regular Price for 16 oz is $29.99. Today's price is $21.62!
  • Most noted for its ability to easily remove imperfections, good work time, easy removal process and brilliant finish
  • You'll instantly notice more gloss and depth with just one application
  • Can be applied by hand but optimal results are with a buffer and an Orange or Cyan Light Cutting Pad from Lake Country
  • A premium medium to heavy cutting polish removing visible surface imperfections while finishing down remarkably well
Today's Daily special (May 20, 2015) is DI Accessories Razor Blade and Mini Plastic Holder.
Regular Price is $1.99. Today's price is $1.09!
  • Pocket size plastic scraper with one single edge razor blade
  • Quickly remove inspection stickers and registration stickers
  • Use for virtually any scraping, trimming, or cutting
  • Open or close with easy push button lock system
Today's Daily special (May 21, 2015) is Menzerna Super Finish Polish SF 4000.
Regular Price for 16 oz is $29.99. Today's price is $21.97!
Regular Price for 32 oz is $44.99. Today's price is $34.80!
  • One of our favorite polishes that removes, oxidation, swirls and light imperfections
  • Easy to use with long work times and easy removal
  • Most commonly applied with a White or Tangerine Lake Country Pad for a great combination of polishing power and gloss
  • Super Finish Polish SF 4000 helps create the shine which you can enhance with any sealant or wax afterward
Today's Daily special (May 22, 2015) is DI Brushes Leather and Vinyl Scrub Brush.
Regular Price is $3.99. Today's price is $2.73!
  • Outstanding leather care brush to deep clean leather!
  • Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
  • Soft and gentle leather brush that works great
Today's Daily special (May 27, 2015) is DI Microfiber Grey on Gray Towel.
Regular Price for 16" x 16" is $3.99. Today's price is $2.30!
  • Tight weave and low/medium nap for easy removal of polish, wax, sealants, etc
  • Can be used to clean and apply virtually any product
  • Use it on the vehicle's interior and around the home!
  • Soft fibers are safe and effective!
  • Can be washed hundreds of times, we recommend Micro-Restore Microfiber Detergent Concentrate
  • 307 GSM
Today's Daily special (May 28, 2015) is DI Brushes Heavy Duty Wheel Brush.
Regular Price is $4.99. Today's price is $3.22!
  • Clean even the heaviest of build ups off your wheels quickly and easily
  • The stiff blue polypropylene bristles provide extra scrubbing action
  • With a simple rinse this brush is clean for future uses
Today's Daily special (May 29, 2015) is Chemical Guys Meticulous Matte Detailer (MMD).
Regular Price for 16 oz is $19.99. Today's price is $12.05!
  • Finally a product designed to care for matte and flat finishes
  • Helps clean and protect in one easy step
  • Spray it on a microfiber towel or directly on the surface and wipe with light pressure
  • Will not leave any white residue behind
  • Contains no waxes or silicone
Today's Daily special (June 1, 2015) is DI Brushes Toothbrush Style Detail Brush.
Regular Price is $1.99. Today's price is $1.17!
  • Remove dirt and debris from small seams and crevices safely and easily!
  • Easy to grip plastic handle with grooved "finger-grips"
  • Soft and safe horse hair bristles
  • Durable construction for regular usage
Today's Daily special (June 2, 2015) is DI Microfiber Black and Yellow Towel.
Regular Price for 16" x 16" is $4.99. Today's price is $3.09!
  • Two sided towel that is perfect for cleaning inside and out
  • Plush on one side with a shorter nap on the other
  • Tag less design with bounded edges for added durability
  • Safely and easily removes polishes, sealants, waxes, etc.
  • Can be cleaned with the Micro-Restore Microfiber Detergent Concentrate
  • 407 GSM
Today's Daily special (June 4, 2015) is DI Microfiber Two Sided Large Towel.
Regular Price for 16" x 24" is $4.99. Today's price is $2.99!
  • This two sided towel is perfect for cleaning a variety of surfaces!
  • One of our largest microfiber towels measuring 16" x 24"
  • Silk edging helps minimize adding imperfections to delicate surfaces
  • We always recommend washing your microfiber products before the first use (ie DI Microfiber Micro-Restore Microfiber Detergent Concentrate)
  • 365 GSM
Today's Daily special (June 5, 2015) is CarPro Iron X Iron Remover Lemon Scent.
Regular Price for 500 ml is $18.99. Today's price is $11.91!
Regular Price for 1000 ml is $29.99. Today's price is $20.01!
Regular Price for 4 L is $99.99. Today's price is $67.35!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Lemon scented with improved formula!
  • Also available in Cherry Scent!
Today's Daily special (June 8, 2015) is Meguiar's Soft Buff DA Foam Polishing Disc.
Regular Price for 5" is $10.99. Today's price is $7.67!
Regular Price for 6" is $12.99. Today's price is $9.07!
  • Polishing disc that makes quick work of medium to light imperfections!
  • Low operating temperature and less haze left behind
  • Thin 17.5mm disc design
  • Works on the MT300 or any other DA Polisher
  • Perfect fit on the Soft Buff DA Backing Plate
Today's Daily special (June 9, 2015) is Lake Country Hydro Tech Cyan Light Cutting & Polishing Pad.
Lake-Country-Hydro-Tech-Cyan-Light-Cutting-and-Polishing-Pad-65-inch_406_1_m_2595.jpg
Regular Price for 6.5" is $11.99. Today's price is $7.31!
Regular Price for 5.5" is $9.99. Today's price is $6.24!
Regular Price for 4" is $5.99. Today's price is $3.80!
Regular Price for 3" is $3.99. Today's price is $2.49!
  • Powerful cutting action but the ability to finish down haze free
  • Hydro Tech foam keeps more polish on the surface of the pad for longer work time
  • Experience less dusting than traditional foam pads due to less product build up
  • Lake Country Snappy Clean Pad Cleaner help clean these pads
  • Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
Today's Daily special (June 10, 2015) is DI Microfiber Ultra Plush Two Sided Towel.
Regular Price for 16" x 16" is $5.99. Today's price is $4.25!
  • Our most popular towel for applying quick detailers, plush on one side and medium nap on the other
  • Works excellent as an interior duster towel which you can easily store in your glove compartment
  • Perfect for giving those final wipe downs after removing a sealant or wax
  • 530 GSM
Today's Daily special (June 11, 2015) is Meguiar's Soft Buff DA Foam Finishing Disc.
Regular Price for 5" is $10.99. Today's price is $7.78!
Regular Price for 6" is $12.99. Today's price is $9.19!
  • High quality finishing disc to remove light imperfects and leave behind an amazing finish!
  • Low operating temperature and clarity when used with your favorite finishing polish
  • Recommended on the MT300 or any other DA Polisher
Today's Daily special (June 12, 2015) is DI Accessories Chemical Resistant Spray Trigger.
Regular Price is $2.99. Today's price is $2.19!
  • A high quality trigger meant to withstand strong cleaning agents
  • Can spray a fine mist or a direct stream
  • Works great with virtually any bottle including the DI Accessories Trigger Spray Bottle
Today's Daily special (June 14, 2015) is Chemical Guys Polishing Pad Conditioner.
Regular Price for 16 oz is $9.99. Today's price is $6.89!
  • Get the most out of polishing by keeping your pads fresh with the Foam Pad Conditioner
  • Simply give a quick mist to your buffing pad prior to applying your polish to the pad
  • Do not saturate your pad with product, only a mist is needed to prime the pad initially
Today's Daily special (June 16, 2015) is Meguiar's Carpet and Upholstery Cleaner D102.
Regular Price for 19 oz is $5.99. Today's price is $4.20!
  • Removes dirt, oil, and stains from carpets and upholstery fast and easy
  • Quick drying no mess formula, perfect for enthusiasts and pros!
  • Upside-down spray application allows you to use it at any angle
  • Works great with the DI Horse's Hair Upholstery Brush or the DI Carpet Scrub Brush.
