New FREE Car Care Product every week at DetailedImage.com
This week's Weekly Special is DI Accessories Detailed Image Kneeling Pad.
Use Coupon Code WSDETAI3417 to receive it for Free. A $6.99 value! Min spend $50. Offer ends 8/29/17 at 11:59 PM EST.
  • Use it as a kneeling pad or as a seat cushion
  • It's weatherproof and durable!
  • Thin design yet very strong for great support
  • Proudly display your love of Detailed Image!
  • Measures 8" x 15"
This week's Weekly Special is DI Microfiber All Purpose Towel Blue - 16 x 16.
Use Coupon Code WSALLPU3517 to receive it for Free. A $3.99 value! Min spend $10. Offer ends 9/5/17 at 11:59 PM EST.
  • Our most versatile microfiber towel, most commonly used to apply and remove a variety of products
  • Easily remove polish residue, glazes, sealants and waxes with the medium nap microfiber towel
  • Works great for the interior, leather, glass, wheels and so much more
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
  • Store microfiber products in a DI Accessories Reclosable Storage Bag to preserve your towels
  • 350 GSM
This week's Weekly Special is DI Brushes Vent and Dash Boar's Hair Detailing Brush - 10".
Use Coupon Code WSVENTA3617 to receive it for Free. A $9.99 value! Min spend $35. Offer ends 9/12/17 at 11:59 PM EST.
  • Perfect brush to clean around hard to reach interior surfaces
  • 2.5" long bristles made of soft natural Boar's Hair
  • Handle made of high quality durable ferrule
  • Easily clean buttons, nobs, vents, radios, speakers, seams, crevices and more!
This week's Weekly Special is Grit Guard Washboard - Black.
Use Coupon Code WSWASHB3717 to receive it for Free. A $12.99 value! Min spend $45. Offer ends 9/19/17 at 11:59 PM EST.
  • Cleans your wash mitt, sponge, brushes, etc.
  • Helps prevent swirls and scratches while washing
  • Attaches to your Grit Guard
  • Works great in 5 gallon and 3.5 gallon buckets
This week's Weekly Special is Gtechniq AP2 Ultra Soft Foam Filled Microfibre Applicator.
Use Coupon Code WSAPULT3917 to receive it for Free. A $2.49 value! Min spend $10. Offer ends 10/3/17 at 11:59 PM EST.
  • A great applicator for applying Gtechniq coatings and any other coating!
  • Foam applicator covered in dense microfiber
  • Can also be used to apply your favorite sealants, waxes, etc.
  • Measures 8cm in diameter and 1cm thick
This week's Weekly Special is DI Accessories Chemical Resistant Spray Trigger - Standard.
Use Coupon Code WSCHEMI4017 to receive it for Free. A $2.99 value! Min spend $10. Offer ends 10/10/17 at 11:59 PM EST.
  • A high quality trigger meant to withstand strong cleaning agents
  • Can spray a fine mist or a direct stream
  • Works great with virtually any bottle including the DI Accessories Trigger Spray Bottle
  • Comes in two great styles, Standard and High Flow
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL4117 to receive it for Free. A $19.99 value! Min spend $85. Offer ends 10/17/17 at 11:59 PM EST.
  • Degrease nearly any surface safely and effectively
  • Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
  • Can be used at full strength or diluted down to clean more delicate surfaces
  • Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
  • A must have any detailing enthusiasts or pro detailers arsenal of products
This week's Weekly Special is DI Microfiber Applicator Pad - Rectangle.
Use Coupon Code WSAPPLI4217 to receive it for Free. A $2.99 value! Min spend $5. Offer ends 10/24/17 at 11:59 PM EST.
  • Ideal for applying a sealant or wax, can also be used for polishes, glazes and more
  • Very soft and safe applicator
  • It should last years if you hand wash the Microfiber Applicator
  • Can be used to apply interior care products like leather cleaners and conditioners, trim restorers and other protectants
  • 300 GSM and reusable!
  • Comes in two great shapes, rectangle and circle!
Use Coupon Code WSTOTAL4317 to receive it for Free. A $19.99 value! Min spend $105. Offer ends 10/31/17 at 11:59 PM EST.
This week's Weekly Special is Lake Country CCS Orange Light Cutting Pad - 5.5".
Use Coupon Code WSCCSOR4417 to receive it for Free. A $7.99 value! Min spend $30. Offer ends 11/7/17 at 11:59 PM EST.
  • Great pad for applying your favorite polish
  • CCS dimple technology reduces friction and heat
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
  • For best results, follow up with the CCS White Polishing Pad and your favorite finishing polish
  • Helps work in medium to heavy cutting polishes
This week's Weekly Special is DI Microfiber Green Monster Hybrid Car Wash Mitt - 9" x 9".
Use Coupon Code WSGREEN4517 to receive it for Free. A $10.99 value! Min spend $35. Offer ends 11/14/17 at 11:59 PM EST.
  • Safely remove dirt and grime from your paint
  • Different lengths of microfiber help clean the micro-ridges of your clear coat
  • Can be used as a wash pad or wash mitt
  • Measures 9" x 9"
This week's Weekly Special is Lake Country Snappy Clean Boost Pad Cleaner.
Use Coupon Code WSSNAPP4617 to receive it for Free. A $1.49 value! Min spend $5. Offer ends 11/21/17 at 11:59 PM EST.
  • A citrus degreaser designed to help release product and contamination from foam pads
  • Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
  • To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
Use Coupon Code WSAPPLI4717 to receive it for Free. A $2.99 value! Min spend $5. Offer ends 11/28/17 at 11:59 PM EST.
  • Comes in three great varieties!
This week's Weekly Special is DI Accessories Precision Bug Scrubber.
Use Coupon Code WSPRECI4817 to receive it for Free. A $6.99 value! Min spend $30. Offer ends 12/5/17 at 11:59 PM EST.
  • Helps you easily remove dirt, grime, bug splatter, and more
  • Easy to hold, lightweight handle design
  • Six sided shape makes cleaning a breeze
  • Rinses clean with ease
This week's Weekly Special is DI Microfiber Double Thick Edgeless Towel - 16"x16" Blue.
Use Coupon Code WSDOUBL4917 to receive it for Free. A $5.99 value! Min spend $30. Offer ends 12/12/17 at 11:59 PM EST.
  • Edgeless design saves you time while improving results!
  • Very plush, long, and soft microfiber threads
  • Very durable design that can be machine washed
  • Can be used for virtually any detailing task
  • 470 GSM
This week's Weekly Special is DI Brushes Foam Pad Cleaning Brush.
Use Coupon Code WSFOAMP5017 to receive it for Free. A $1.99 value! Min spend $10. Offer ends 12/19/17 at 11:59 PM EST.
  • Helps remove excess product trapped in your buffing pad
  • Safe on all foam pads and very easy to use
  • Helps prolong the life of pads and keep them in ideal working condition
  • 8" contorted handle and .75" nylon bristles
This week's Weekly Special is Rupes White Finishing Foam Pad - 1.25".
Use Coupon Code WSWHITE5117 to receive it for Free. A $6.99 value! Min spend $30. Offer ends 12/26/17 at 11:59 PM EST.
  • Bring back that deep glossy finish safely and easy!
  • Removes ultra fine imperfections and finishes down extremely well
  • Pairs great with the Rupes Diamond Ultra Fine Gel Polish
This week's Weekly Special is Lake Country Force White Polishing Pad - 3.5".
Use Coupon Code WSFORCE5217 to receive it for Free. A $4.99 value! Min spend $25. Offer ends 1/2/18 at 11:59 PM EST.
  • Remove fine imperfections like swirls, spider webs, oxidation, etc.
  • Pair with your favorite finishing polish
  • Hybrid foam technology keeps the polish on the surface of the pad
  • We recommend cleaning and caring for your pads with the Lake Country Snappy Clean Boost Pad Cleaner
This week's Weekly Special is Lake Country Microfiber Polishing Pad - 5.25".
Use Coupon Code WSMICRO0118 to receive it for Free. A $10.99 value! Min spend $40. Offer ends 1/9/18 at 11:59 PM EST.
  • Remove light to medium imperfections with ease
  • A great compliment to Lake Country Microfiber Cutting Pads
  • Foam backed and 11mm thick design
  • Unique microfiber material mats down less reducing surface temperature
  • Finishes down extremely well!
This week's Weekly Special is Chemical Guys Maxi Suds II - 16 oz.
Use Coupon Code WSMAXIS0218 to receive it for Free. A $8.99 value! Min spend $35. Offer ends 1/16/18 at 11:59 PM EST.
  • One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
  • An addicting cherry scent that makes washing your car a pleasure
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
  • High sudsing formula makes this a great option to use in foam guns
This week's Weekly Special is DI Accessories Fine Grade Clay Bar - 100 g.
Use Coupon Code WSFINEG0318 to receive it for Free. A $10.99 value! Min spend $25. Offer ends 1/23/18 at 11:59 PM EST.
  • Safely remove road grime, brake dust, tar, sap, paint over spray and more
  • Fine grade clay bars are gentle on your exterior paint
  • We recommend using Dodo Juice Born Slippy or Poorboy's World Spray & Wipe as your clay lube
  • Can be used on brand new cars to older vehicles with light to medium build ups
Use Coupon Code WSFOAMP0418 to receive it for Free. A $1.99 value! Min spend $10. Offer ends 1/30/18 at 11:59 PM EST.
This week's Weekly Special is DI Accessories Wash Bucket Sticker - Grey.
Use Coupon Code WSWASHB0518 to receive it for Free. A $1.99 value! Min spend $5. Offer ends 2/6/18 at 11:59 PM EST.
  • Label your Wash bucket with a beautiful DI sticker!
  • Help reduce bucket confusion and cross contamination
  • DI Accessories Rinse Bucket Sticker available as well!
This week's Weekly Special is DI Brushes EZ Detail Brush - Mini Size.
Use Coupon Code WSEZDET0618 to receive it for Free. A $10.99 value! Min spend $75. Offer ends 2/13/18 at 11:59 PM EST.
  • The professionals choice for a wheel brush to clean the inner barrels of your wheels
  • Mentioned as an essential tool professionals use in Autoweek magazine
  • Works great with soap and water or a wheel cleaner for maintaining wheels
  • Turns a good wheel detail into an exceptional one that really shines with open spoke wheel designs
  • Can also be used in your engine bay to agitate contamination after degreasing
