Lucky_Ls
No it stay right under the 3 quarter mark when it's sitting. I didn't want to drive it anymore and put more heat on the engine.
i feel the same way, its one thing after another after another. i finally fixed mine from overheating and now something else is going wrong with it.
I'm bringing back my old thread because I'm having the same problem! Although not as bad the car doesn't overheat Per Se it just runs hot. The temp gauge will get close to the 3/4 mark then go back down near to normal operating tempature (middle) but not right where it normally runs just a little above. I recently got it back from the body shop and just before the little scrape I had it did this exact same thing. The guy at the body said he had it run hot on him as well but he just kept driving it and the temp did as previously stated.
He mentioned that it may be my thermostat?
I don't know what the LS's OEM thermostat is rated/degree or whatever is set for so if somebody knows out there can you help me out with this?
